Fair price for machine work & labor to build a stroker motor?
Originally Posted by 2001 Pewter WS6
I wanted to buy everything as a matched set. It is a very nice and complete kit from Lunati. It may cost a bit more, especially since the Eagle Cranks are out, but I had zero issues installing it...
Originally Posted by Reckless
That's a great price considering you used Lunati products. Not bad at all!
Chris, I know you were not referring to me, just wanted to make a point
I definately think you'd get a lot of business assembling shortblocks for a reasonable price, especially after you did a few and people saw you were doing quality work. I too have gotten irritated at the price gouging that seems to go on in the LS1 aftermarket community, some of the quoted prices I've seen are ridiculous from H/C packages to assembled shortblocks.
These are the best sponsor deals on 382 short block/long blocks I've seen. Anyone know of a better deal?
Speed Inc.
SPORTSMAN SHORT BLOCK INCLUDES:
-Billet 4.00” stroke 4340 crank
-Billet 6.125” connecting rods
-Diamond Flat top Piston w/2cc reliefs or -8.6cc Boost pistons
-Diamond Pro-select rings
-High performance bearings
-All Gaskets, seals and hardware for short block
-Fully balanced/blueprinted/Finish hone w/torque plate, assembled
$4,599.99
Speed Inc.
SPORTSMAN LONG BLOCK INCLUDES:
-Custom Comp Cams Roller camshaft, Forced Induction or naturally aspirated
-Comp Cams Lifters
-Felpro Head gasket/bolt set
-Double roller timing chain
-SLP blueprinted oil pump
-RGR, MTI, GTP or AFR heads
$6,299.99 w/RGRheads
$6,999.99 w/GTP or MTI heads
CARTEK SMALL BORE 382 CID LS1 SHORT BLOCK
Lunati 4340 pro series crankshaft 4.000" stroke
Scat 4340 connecting rods 6.125"
JE custom forged pistons
Plasma moly rings set
Clevite H series race bearings
Rotating assembly fully balanced
Engine blueprinted
Cartek hyd. roller cam
Double roller adjustable timing chain
Fully assembled short block (Engine core required)
$6,750.00
MTI 383cid Stroker Engine Package
MTI can also provide a 383cid (6.3L) engine package using a non-modified LS1 block and a forged stroker crankshaft kit. This engine setup includes a stock aluminum LS1/LS6 block, 4.00" forged stroker crankshaft, custom forged pistons and rings, custom billet connecting rods, all new bearings,
Price MTI 383cid Stroker Shortblock $5,995 +exchange
Speed Inc.
$4,599.99
Speed Inc.
-Comp Cams Lifters
Engine blueprinted
$6,750.00
The machine shop I use is state of the art and regularly build $20k+ race hemis. They have so many NHRA trophies in their shop they have to build new shelves all the time
I appreciate the education on the pricing.
Thanks
Oh as for the Lunati assembly for a sweet deal call TBryne...it's well worth the phone call if you want the Lunati. Trust me.
Spohn had the Eagle crank for $820 and I was adding in what it cost to buy piston, rods, bolts & rings seperate. Balancing might be a little high.
I called Speed Demon they had them sell them for around $2000
i would love to put an ls1 into my 89
i thinking instead of just buying an ls1 and puting it into my car that i will build a stroker in a iron block 6.0L
get 4.125 crank and all the other stuff
i might be better off
#32
I had Joe Jolly of LPE build my short block I think by the time all of the Labor,Balanceing,Align bored and hone,Machine,Assembly and all that it ran right in the range of $3000. No parts. It has Lunati crank, Ross piston, and all of the high quality parts so it will only have to be a one time purchace hopefully. Im happy with it runs real strong for a 8.9-1 motor. Idles like a champ.
#35
H82BBad, thanks for the info I didn't think about the rod bolts may being an issue with aftermarket rods and the crank being ok.
#36
Damn that sucks they didnt have a clue where it went to? U gonna come to BG and race when you get that new setup done? Im kinda anxious to see what u can get it to run. Later Justin
#38
Originally Posted by DIAMOND
Remember guy's, you get what you pay for.
My version is : "You may not always get what you pay for but you rarely get what you don't pay for."
Choose your builder carefully.
#39
BTW Machine work for my block was
80.00 to hone it, 25.00 to clean it, and 30.00 to install cam bearings I clearenced it for my rods here at the house.
I bought my stoker kit used on here for 2100.00
#40
10 Second Club + 14 Second Truck Club
