tr224 vs 226/229
98 heads will be VJ bowl work mild port and milled to whatever works best
ls6 intake
1 3/4 headers 3/4 FM merge 4' bullet
Powerglide with 4500 stall
4.10 rear gears with 28 inch tires
What would i pick up going from tr224 to a 226/229 580/580 112?
What would be shift point on the 226/229? Little worried about spinning a 98.
The car will be sprayed often with a 150-175 shot.
Go at least to a v2, v3, ms3, or some other variation in that range to make it worth it
The reason for staying small is I want my shortblock to last awhile. I'd like to keep the shift point to 6500 or less really.
What are you guys shifting your smaller 230 cams at? Goal is bottom 11's/10.9's on motor and 10.3's or lower on spray
A glide doesnt have a step first gear like a Th400/350 does you moron so a glide is BETTER for a smaller tire. Why do you think the outlaw 10.5, outlaw radial, anything that runs a small tire is either running a glide or a TH400 changing to a TH210 which uses a less-steep first gear ratio to get the car to leave and not spin? Get a clue.
High RPM's through the traps have to deal with tire HEIGHT, gear ratio, and converter slippage.
To the OP, my 230/236 shifts at 6200 or so.
