Best cometic head gaskets?
Old Feb 6, 2010 | 12:00 PM
Boost-box's Avatar
Default Best cometic head gaskets?
What would be the best cometic head gasket to use for my boosted 5.3? I am using 317 heads on a 5.3 non-decked block: should I invest in the machine work for shaved heads and a decked block?
Old Feb 8, 2010 | 11:07 AM
Boost-box's Avatar
Old Feb 8, 2010 | 01:55 PM
conan's Avatar
Are the heads new? How many miles on the block? You could always go to a GM MLS gasket for the 6.0L.
Old Feb 8, 2010 | 02:20 PM
mark21742's Avatar
I'd go with a 5.3L MLS gasket with .051" thickness to give proper quench area if your running stock pistons with an undecked block.
Since your boosted I wouldn't mill the heads (unless they need trued up), but if you get the heads ported you PSI will drop, and at the same time make more power because of the increased flow
Old Feb 8, 2010 | 02:29 PM
conan's Avatar
A 5.3l gasket wont clear the 72cc combustion chamber in the 317 heads. You need to use a 6.0L gasket (.051 thick as well) or a cometic 4.030 bore. These are what I'm running on my ls1 with 317's http://www.texas-speed.com/shop/item...d=603&catid=36
Also is engine going to be street driven? If so I would shoot for 9.5:1 compression so getting the heads shaved a little bit is probly not going to matter much.
Old Feb 9, 2010 | 04:25 PM
Boost-box's Avatar
The heads have roughly 80K on them. I am going to have them checked once I receive them. the engine will be street driven as well, using all stock internals and the heads will be left stock as well. I dont plan on decking the block either.
Old Feb 9, 2010 | 07:42 PM
mark21742's Avatar
I just bought my 6.0l .051 gaskets at the dealership for $104 for the pair
thanks for clearing up my mistake, didn't realize the clearance was that close on the valves
Old Feb 9, 2010 | 08:06 PM
Boost-box's Avatar
So what would be better? An aftermarket cometic or would the OEM 6.0 MLS gasket be enough?
Old Feb 9, 2010 | 09:15 PM
conan's Avatar
I would go with the GM MLS and have the heads milled. Do you know what the compression is going to be with untouched 317's (72cc) on the 5.3L ???
Also I would upgrade to dual valve springs, FI needs a stable valve train.
Old Feb 9, 2010 | 09:43 PM
batboy's Avatar
A 5.3 engine with stock pistons, GM .051 gaskets, and 317 heads (72cc) will be somewhere around 9:1 CR.
Old Feb 13, 2010 | 04:34 PM
Boost-box's Avatar
What does the bore size on the MLS gasket have to be?
Old Feb 14, 2010 | 12:29 AM
conan's Avatar
These are the 2 options for the 317 heads.
GM MLS http://www.texas-speed.com/shop/item...d=880&catid=36
Cometic MLS http://www.texas-speed.com/shop/item...d=603&catid=36
Old Feb 26, 2010 | 09:52 AM
Boost-box's Avatar
To bring this thread back I have a question.
Just to be clear so I don't mess anything up.
I need 4.030 mls gaskets to run my 317 heads on my 5.3: correct?
Old Feb 26, 2010 | 10:42 AM
conan's Avatar
Yes... ^^^ These are 2 gasket options for the 72cc combustion chamber in the 317 heads. One is the GM 6.0L MLS gasket. The other is a 4.030 bore in the cometic MLS gasket.
Old Apr 4, 2010 | 10:34 PM
NightmareTA's Avatar
I did a search and stumbled on this thread. I'm just curious....I am running this combo as well. Why do you need a 4.030 bore in the cometic version thats intended for a 6.0? If the engine is not bored, shouldn't you be ok with a standard bore and not a .030 over bore?
Old Apr 15, 2010 | 12:06 AM
swomp rat's Avatar
Another question...? I've seen mls head haskets get coated with some spray on crap (not sure what it was called) before they were installed. Do you guys recommend this on a LQ-9 build?
Old Apr 15, 2010 | 08:02 AM
SOMbitch's Avatar
To match the chamber size of the heads that came off a 4.0" bore motor...
Copper spray because some guys feel cometics need this to help seal better. IIRC Cometic requires an RA of 50 on the sealing surfaces....
Old Apr 15, 2010 | 08:27 AM
Jim85IROC's Avatar
What's the RA on factory surfaces? I've got new LS3 heads and a 6.0 block that I don't intend to get resurfaced.
Old Apr 15, 2010 | 02:41 PM
conan's Avatar
What he said ^^^
I did not use copper spray on my cometics, just wiped the gaskets, heads and block deck with brake cleaner and bolted them on.
Old Apr 15, 2010 | 06:25 PM
SOMbitch's Avatar
IDK what the factory RA is but I have seen plenty of people run out of the box heads with Cometics and no problems..... I wouldn't sweat it at all.
