New style of 918 springs????
Old Feb 8, 2010 | 09:46 AM
RcrX's Avatar
Default New style of 918 springs????
I've been reading alot of how people have had problems with the older style of 918 springs breaking......... Anyone have any problems with the new style?
I just recently purchased a new set..... still trying to figure out wat cam now
Old Feb 8, 2010 | 10:55 AM
01ssreda4's Avatar
Sell em and get PAC 1218s or 1518s.
Old Feb 8, 2010 | 11:18 AM
1979rs/z28's Avatar
I've got pac's 1218 with a .585 lift cam, 5k miles so far and no problems at all!
Old Feb 8, 2010 | 11:54 AM
Quik Sand's Avatar
I have them, no problems at all.
Old Feb 8, 2010 | 09:20 PM
jlrz28's Avatar
10 Second Fun Car
Even with the old 918s Ive had no problems!
Old Feb 9, 2010 | 06:24 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
Another vote for the PAC's. I've got 918's, from a set of the 'good batch' from a while ago, but when I swap springs, it'll be for a set of the PAC 1518s.
Old Feb 9, 2010 | 10:05 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
We've seen no issues with the new 918's (or old for that matter) when they were used in the right applications and setup properly! Too many people just throw a set of springs and a camshaft in and count on .600" lift springs to handle .61x" valve lift without worry. That's not what they were designed to do, and manufacturers put these ratings on them with good reason!
That all being said, we also offer the PAC 1218 and 1518 springs at competitive prices for those who are more comfortable with them.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Feb 9, 2010 | 10:09 AM
Damian's Avatar
LSX Mechanic
Setting them up is key.
If you're running between .525-.575 lift then dropping them in is usually fine. Anything over .575 requires extra assembly IMO. Shimming, checking height, etc..
As Matt said, most people assuming they can run a .595-.600 lift cam no problem with a "drop in" assembly. Another reason sites like ls1howto.com are dangerous.
Old Feb 9, 2010 | 12:03 PM
SOMbitch's Avatar
Setting up springs to the manufacterers recommended installed height should ALWAYS be done even though it requires a little more work. This ensures proper spring pressure and means better valve control and longer life.
Old Feb 9, 2010 | 12:29 PM
KCFormula's Avatar
I WOULD NOT RUN the old 918s!! I am surpised there are still any on the market. I ran the blue stripe 918s for years after breaking a 941. But I'd STAY AWAY from the orange stripe 918s!!!
Old Feb 9, 2010 | 04:37 PM
TooLateVTEC's Avatar
No offense, but why did you buy springs BEFORE a camshaft?
Thats bass ackwards.
Old Feb 9, 2010 | 10:54 PM
Steve Bryant's Avatar
LS1 Tech Veteran
I've been running the original 918 series for over four years with no problems.
Steve
Old Feb 10, 2010 | 11:43 AM
Bad Blu Formula's Avatar
No problems with the old set or the new ones. Like stated before, it is important that they are set up properly.
Old Feb 10, 2010 | 06:04 PM
SweetS10V8's Avatar
Im running the new 918s on mine with .607/.621 lift, without issue. I did take the time to set them all up .060" from coilbind.
Ive also ran them on probably 10 other engines and beat the crap out of them. No issues.
Old Feb 11, 2010 | 01:31 AM
Sk8phreak88's Avatar
I'm running the old ones in my lt1. 236/242 with .555/.576 on a 112. No issue here reving to 6250 all the time. Just need to make sure they are set up properly!
Old Feb 11, 2010 | 02:10 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Not that its good info, but I ran a 244/248 .615/.622 cam on older 918's for 20k but before that there were 3 other cams on the same springs. IMO they are sort of under rated because they know what they CAN handle as opposed to what they advertise just to keep a lower failure rate.
I was probably lucky and they were probably worn out, but I dont think they are a bad spring at all.
Old Feb 11, 2010 | 06:12 AM
PRE-Z06's Avatar
new 918s here with .605/.604 XFI lobes revving to 7k for 8k miles now
Old Feb 22, 2010 | 08:54 AM
RcrX's Avatar
I got a good deal on the new 918s so i jumped on it....... I'm looking into getting an EPS ca m 222/226 113lsa .592/.597 lift
