Daily driver cam?
They told comp I wanted to build NA stay stock cubes and wanted to eventually add heads down the road. They suggested in the 228r and vrx4 duaration cam areas. Needless to say I went with nearly a VRX4 but they added 2 Degrees of timing. Car made 390/375 while at a slightly rich 12.5 a/f with stock 241's and stock ls6 intake no UD pulley (yes i had 85mm tb but it had funnel adaptor and likely wasnt more HP than stock tb) A good tune is KEY! 40mph 6th gear 1,000 rpm no problems
Heres my graph
