Cam and gear question
Old Feb 11, 2010 | 06:34 PM
01SSRMS's Avatar
Default Cam and gear question
Just looking for feedback from anyone with a similar experience. I have an MS4 complete cam kit and honestly I'm kinda itching to get it installed. However, I am still running stock 3:42's. I know it would be faster at the track with 4:11's, but would it be terrible just to drive around on the stock gears and then later do the gears or better yet, replace with a 12 bolt or 9" set up. Let me know if you've run that set up and how it went. Thanks!
Old Feb 11, 2010 | 07:54 PM
drone's Avatar
I just found out today what gears I have.
gotta love a stall.
Old Feb 11, 2010 | 09:44 PM
PAULZ98SS's Avatar
Im thinking of doing the same thing. as far as i hear it'll be ok to drive. maybe sluggish off the line.
Old Feb 11, 2010 | 09:51 PM
1SLwLS1's Avatar
^^^ you're half right, If you aren't leaving off the limiter, you're leaving time on the track. With this cam, it wont be sluggish. As far as street driving, HA, its just like stock down low, that is until you mash the pedal.
Old Feb 11, 2010 | 10:02 PM
Mazzenger's Avatar
I had an MS3 and 3:23 gears in my Z. It worked fine, but was sluggish until 60mph. It turned into a different car after the 3:73 gear swap! Gear swap - good mod!
The 3:42 gears will be ok, but 4:11s will compliment and complete the cam swap.
It will be quicker and you will feel it pull harder.
Old Feb 11, 2010 | 10:24 PM
1SLwLS1's Avatar
Of course it will pull harder, thats what torque multiplication is.
Look, I understand the point of gears + big cam, to get you to your powerband quicker, but the same can be said about cam or no cam, ANY set up. I just don't see it as a requirement like everyone else does.
Old Feb 11, 2010 | 11:49 PM
Austinma62's Avatar
I am no pro in this subject but think of it this way. When you were a road a bike as a kid, would you ride up hill in 6th gear or down shift into first? Half way up hill my legs get tired and need gear for me to move easier in. Kinda the same way the rear gears are. The higher numerical value of rear gears you have, the faster and easier it will accelerate. Hope this helps.
Old Feb 12, 2010 | 09:37 AM
1SLwLS1's Avatar
No one is doubting the usefulness of gears. I am doubting the requirement for cam cars.
Old Feb 12, 2010 | 02:04 PM
Austinma62's Avatar
There is no "requirement" its just highly recommended. Just like long tube headers. Yeah its not required to have them, but there is an advantage to using them.
Old Feb 12, 2010 | 05:17 PM
VaderZ's Avatar
I'd get atleast 373's with that cam.
Old Feb 15, 2010 | 04:12 PM
1SLwLS1's Avatar
I know that there is not a requirement, but highly recommended, I just don't see it. There is an advantage to use most aftermarket performance parts period, not just after a cam swap. If there wasn't, why would people use them.
