Leak Down Results
I don't know who leak-down tested your motor, but I am 99% sure you were lied to. A stock motor is never going to leak-down that low. I guess you keep listening to people who don't know about these cars
R1, Not quite sure if you're calling me an idiot or trying to help but thanks for your input all the same.
I'd believe that all the cyl's were within 2%, but 2% seems low to me. But hey, if it's that good, go with it!
fwiw, my race motor's about 12 to 15%, but that's gapped for 400hp of nitrous, so it's normal.
A stock factory built engine is going to be from 5-10% REALISTICLY.
If those numbers are good your pistons and cylinders are in excellent condition.
Sorry but i still don't beileve your test results. Are you sure Elvis didn't test it? LOL
Thanks for all the input folks. I am learning to filter through all the varying degrees of relevance.
starting at drivers side front and working around to the passenger side front, I used 75 psi in and did not rotate any of the cyl to BDC or at all for that matter all test was done at what ever location in the bore the piston happened to be at, all test was done with no rockers installed so the valves was all closed.
75 input pressure.
62 driver side front
74
60
65 driver side rear
73 passenger side rear
73
73
72 passenger side front
ok so as you see 1 cyl was 75 in 74 out and a bunch was 73 so indeed 2% or less is possible, miles on the motor are unknown, but it runs like a champ and only smokes after a hard pull and i let it decelerate hard and then get back in it. the most deposited spark plug was the one from the 74 cylinder which was the best leak down number lol, i figure the oil was the valve seals and yes i replaced them to. any way it seems my best is 2% or better and my worse is 15% so there is a 12% variance between best and worse. The car goes on the dyno in 2 weeks and the boost gets turned up so the way i see it at least 3 of my cylinders are already loose enough for higher boost hahah.
