CAM or Gears?
A stall converter will give you a bigger ET reduction than the gears ,but the gears are a step in the right direction . What size stall should I get with 2.73 and eventually 3.42 to 3.73?
I have searched the site and I had it narrowed down, but I will tell you in all of my searching I saw a lot of cam recommendations but I never would have equated a cam with gear ratios. I have done research on all of my parts, I got deals on them and I weighed the pro's and cons, and in all of the parts I have bought I regret nothing. I am actually excited about looking into a stall converter now. These guys seem like they know there stuff. So if they are willing to help me I appreciate it.
. Now I have a Yank 4000SS sitting on my tool box ,ready to go .Then Im putting a mid- sized cam in it . Ive seen relatively stock F-bodys (stock exhaust and all )with a 3600 -4000 rpm converter going mid 12's with a killer 60ft ! If your doing a cam soon , look into a 4000 rpm stall , if not, a 3600 will work great . Check with our sponsors on which converter is right for you .
. Now I have a Yank 4000SS sitting on my tool box ,ready to go .Then Im putting a mid- sized cam in it . Ive seen relatively stock F-bodys (stock exhaust and all )with a 3600 -4000 rpm converter going mid 12's with a killer 60ft ! If your doing a cam soon , look into a 4000 rpm stall , if not, a 3600 will work great . Check with our sponsors on which converter is right for you .Thank you everybody I appreciate the help. You guys are the reason why these forums work.
You mentioned you like to cruise on the highway, the 3.73s will make your RPM higher and MPG lower. The stall will lockup and drive just like your stock converter (except when you punch it, then
)I have installed I think a 3500 stall in a car with 2.73s and it really helped. 2.73s are not good for getting into the engine's powerband, the stall will jump you up there. Yes, it will feel a little loose when you first do it with those gears, but you'll get used to it fast and it really isn't that bad.
If your driving habits don't change, (i.e. try not to enjoy your new mod too much) gears will affect your your highway mileage more than the stall. The stall will cost you more in the city and retain your highway mileage, unless you drive hilly or mountainous roads that keep the converter from locking.
As for the tech as TSP, if you point blank asked what cam is the max for a stock stall, he gave the textbook answer, and about the smallest cam they offer. I'd guess they would recommend a stall for that cam too, but none of the cams listed on their website recommends a converter, only tuning. Anyone with a working knowledge of cams understands the powerband and the gears and/or stall speed requirements. You can fudge a little, but it's not like he told you to run the MS4 with a stock converter....
I bought my car with the intention of getting rid of the 2.73s ASAP. 3.42s made a huge difference. Driveability will be poor with either a stall or cam and 2.73s. Get the gears and go from there.
Weiand for 300 including porting
BBK for 100 bucks
Flowmaster came on the car...better than stock
Sorry I think I made the right ones......
