aluminum vs iron heads
I building a forgen LS1 and i have 873 iron heads witch flow the same as 317 heads. My concern is putting iron heads on aluminum block and the motor being boosted. I know the that iron head don't dissipate heat as fast as aluminum heads. So what do you guys thunk?
Casting Number 873
Head: 1999-2000 LQ4 6.0 Liter Truck
Material: ***Cast Iron***
Part Number:
12561873
Combustion Chamber Volume: 71.06cc
Compression Ratio: 9.5:1
Intake Port Volume: 210cc
Exhaust Port Volume: 75cc
Intake Valve Diameter: 2.00 inches
Exhaust Valve Diameter: 1.55 inches
Casting Number 873
Part Number:
12561873
im not an expert by any means but to my understanding the aluminum heads will also help prevent detonation which is a big reason to run them especially with a boosted motor unless ur just building a really budget build that will have a spot on tune.
Iron heads are not a good friend of boost. A full Iron set up does not make any sense weight wise. Even then you see a lot of guys running an Iron block with Aluminum heads. This is because heat retain ability of iron compared to aluminum is much greater (about 10X more) making detonation a big issue in the combustion chamber. Do what you must but that set up is not looking good.
I would go ahead and try to find a set of aluminums if you have some extra budget $$.
Aluminum heads can take almost a full point more compression and be fine on pump gas, which means in your case (F.I.) that it can handle more boost before detonation leading to catastrophic failure.
Good luck
Good luck
