Timing chain question
Old Feb 13, 2010 | 08:31 PM
User_name's Avatar
Default Timing chain question
Im looking for a good and somewhat cheap adjustable single roller timing chain. I would like something that will last and will not stretch in a couple thousand miles. My question is what would I want...Rollmaster, Nmotion, or Cloyes? I did a search but I kept getting a mix of double vs single roller. Thanks
Old Feb 13, 2010 | 11:37 PM
batboy's Avatar
I personally like the Cloyes.
Old Feb 15, 2010 | 10:17 AM
Jon@Texas-Speed's Avatar
We have run a LOT of the N-motion and Rollmaster without a problem. Either one of their single roller chains should work great for you. Let me know if you need on and we'll get you fixed up!
Jon
Old Feb 15, 2010 | 11:04 AM
printmanjackson's Avatar
I think you might have a problem finding what you want using "good" and "cheap" together.
If you want a good single chain then be prepaired to pay, they are not cheap.
https://ls1tech.com/forums/generatio...ing-chain.html
But then again you can always go with the LS2 chain. Thye are cheap for the quality.
Old Feb 15, 2010 | 12:00 PM
hcb1700's Avatar
Texas-Speed has many good timing chain setups at good prices. The LS2 chain would be a good piece to use.
Old Feb 16, 2010 | 12:11 PM
User_name's Avatar
I already have an ls2 chain but Im going to sell that because I want to degree my cam and I was thinking either N montion or Rollmaster but havent really heard much about them.
Old Feb 16, 2010 | 03:52 PM
vettenuts's Avatar
If you have the time, install the cam with the LS2 chain. Then degree the cam. You may find you don't need an adjustable set. Then if you do, you can get one and re-install.
Old Feb 16, 2010 | 05:21 PM
saloonwarrior's Avatar
I have a comp cams adjustable one for sale if you are interested? It's a 3153KT
