Looking to get close to 500 with 5k
Old Feb 17, 2010 | 11:31 AM
  #41
jgoo's Avatar
Originally Posted by kmracer
why is the install 4k?
Thats with all the parts included and a tune. labor is only 1150 for cam,stall,gears,and tranny cooler, pluse Royal purple fluids all the way back and they are going to do my plugs and clean my filter for me for free
Old Feb 17, 2010 | 01:02 PM
  #42
novicius's Avatar
What's the specs on the stall? From what I've read here, that's going to be your single most impressive mod -- gears are only going to help drivability, not ET.
Old Feb 17, 2010 | 01:51 PM
  #43
jgoo's Avatar
[QUOTE=novicius;12907790]What's the specs on the stall? From what I've read here, that's going to be your single most impressive mod -- gears are only going to help drivability, not ET.[/QUO
Yank ss 3600 and the most impressive mod to me is the cam the converter is gonna get me staight to where the cam starts making power. I was under the impression that gears would help ET?
Old Feb 18, 2010 | 03:19 AM
  #44
SSdimension's Avatar
[QUOTE=02*C5;12902230][QUOTE=Fb0dy0nly;12902065]Agreed, Im not sure that vararam is going to do him any good, nor will the xpipe or zo6 diff...and why would you pay $450 for a cam? You can have one custom specd by most rep sponsors on here for no more than $350-75, off shelf, prob cheaper..
And I dont think you need a super 2k upgraded 4l60 just to get 400whp...that is just extra insurance, so is new lifters, rockers, and a double roller...extra insurance unless you have a really high mileage motor, then yes, I would replace as well. Higher flowing Injectors are good upgrade to do but unecessary for a cam only setup...
______
Lets be realistic for $5K yeah maybe but not possible.
The way I look at it do it right the first time or don't do it at all. With 500 rwhp do you think that 10 bolt is going to hold up. Yeah maybe for one launch, his best bet is to get get a 9" How much is that going to run him.
If anyone is just looking for big numbers ad a cam and a shot of nitrous and you are there if you want your car to be able to be a reliable street/strip vehicle then you have to take a couple of precautions. Regardless if its an F body a Corvette or even a Honda.
Yank SS4000-$550 shipped
Built Lvl 2 4L60e (labor included)-$1000 local shop
Ls6 ported oil pump-(NEW)$100 shipped
Ls6 heads with dual valve springs some ported work locally-$600
Lg Motorsports G5x4-$250 local
Pacesetter Longtubes ceramic coated-$300
Custom Lanes X pipe-$300 local
Ud 25% pulley(NEW)-$150 shipped
Jet Performace PCM-$60 local
Tik Performance 7.4 pushrods(NEW)-$100 shipped
Granetti MAF-$120 shipped
MSD wires(NEW)-$45 shipped
Mobil 1 Full Synthetic(6qts)and k&N oil filter-$50 local
Transmission oil cooler(NEW)-$60 local
Labor For MOTOR-$800
Total Cost-$4,485. I used a calculator Thats under your budget. Hell you got $515 dollars to spare on a Nitrous 75 dry shot. Made 421RWH through an auto. + 75 shot= make almost 5 and a **** load more of torque. Made high 400's at the crank.
Old Feb 18, 2010 | 04:13 AM
  #45
millersta's Avatar
Originally Posted by 02*C5
Actually E85 is more of a 116 octane rating. .
actually e85 is around 105 octane when u get it from the pump.
Old Feb 18, 2010 | 05:02 AM
  #46
jgoo's Avatar
[QUOTE=SSdimension;12911379][QUOTE=02*C5;12902230]
Good info bro i appreciate you taking the time to break that down thats definatly a route I would like to go. Im gonna talk to my shop today
Old Feb 18, 2010 | 09:38 AM
  #47
novicius's Avatar
I'm not one to say -- this thread seemed informative. Give it a read.
Old Feb 18, 2010 | 10:17 AM
  #48
01ssreda4's Avatar
In an auto car not a whole lot, now M6 is a different story. 3.23 is a great all around gear for auto cars. I used to have it and went to a 3.73. They make traction even harder to come by. But with the gear you can feel it pull through the gears a little quicker. Its kind of a trade off for auto cars.
Old Feb 18, 2010 | 10:30 AM
  #49
jgoo's Avatar
Should I just save the 500 bucks then?
Old Feb 18, 2010 | 10:35 AM
  #50
kinglt-1's Avatar
Just to clear things up here, on a stock converter gears will help quite a bit. When you add a stall, the gears won't help et's because the stall slips up into the powerband regardless of what gear your running. At that point gears just help drivability by making the stall feel "tighter", meaning it will take less throttle to get the car moving. If your not running a good tire with a stall and 3.73's you could actually be slower than lets say a stalled 2.73 setup because of traction as 01ssreda4 pointed out.
