high ratio rockers question
Old Feb 15, 2010 | 11:25 PM
abnaasefmb's Avatar
Default high ratio rockers question
I know someone way smarter than I has figured all this stuff out already, but so I know, anyone want to explain about high ratio rockers. Seem like there would be a balance to be achieved, but higher ratio rocker could open valves faster and wider without the need for extremely harsh cam ramps. Thoughts? thanks
Old Feb 15, 2010 | 11:58 PM
SweetS10V8's Avatar
They would create faster ramps, they are opening faster.
Old Feb 16, 2010 | 06:28 AM
batboy's Avatar
They also change the valve train geometry. It's better to get a cam with the desired lift than to do higher ratio rockers.
Old Feb 16, 2010 | 08:54 AM
KCS's Avatar
KCS
Moderator
They do, but the draw back is extremely high loads on the pushrod. It's an example of one of the earliest mechanical devices in the world: the lever.
When the ratio increases, it's usually the pushrod cup that's moved in closer to the fulcrum, and the spring force on the rocker tip is amplified by the rocker ratio by the time it gets to the pushrod. Say a given spring provides 400lbs of pressure. With a 2:1 rocker, that would be roughly 800lbs of force translated to the pushrod.
Typically, besides the guys that don't really know what in the hell they are doing, the only time a professional engine builder would elect to use a high ratio rocker is when the cam cannot physically be designed with any more lobe lift, or, as in the case of a NASCAR Nextel Cup engine, flat tappet lifters are used, in which case the ramp rates and consequently lift, are limited by the lifter diameter. In those instances, the amplification chracteristic of the rocker makes up for what the camshaft cannot do.
Old Feb 16, 2010 | 04:19 PM
Old SStroker's Avatar
It's a little more involved than that. Think valvetrain stability. That may be more important in a Cup engine than lift. Heck, it may be more important in any engine that runs more than a few seconds at a time in anger. Even those engines benefit from better valvetrain stability at the extreme rpms.
Big ****** pushrods don't really hurt anything, so you really don't have to worry much about mass (and loads) on the lifter side.
Not everyone sees it this way, of course.
Jon
Old Feb 16, 2010 | 05:04 PM
KCS's Avatar
KCS
Moderator
Yeah, I agree. I know there's more to it than just lift, but I just meant that they're gonna end up in the "high" range of rocker ratio just getting the net valve lift that they want. I don't think those Cup guys, in particular, can get the .700"-.800" lift with a stock Chevy 1.5:1 ratio.
Jon
I agree, just except for the unit loading on the pushrod-pushrod cup interface. I've heard of guys running solid billet pushrods and running oil passages through the stands, but at some point, with those 1,000+lbs spring pressures (I know, not Cup springs), those pushrod tips burn up. I think I read that the friction the Cup guys see between the pushrod and pushrod cup in the rocker, have been a major focus to reduce.
Old Feb 17, 2010 | 09:44 AM
abnaasefmb's Avatar
Good to know info, what I thought, someone had already figured it out and just do what everyone else is doing. Thanks
