Power difference between 5.3 and LS6 heads
It really was a poor choice. If I were you I would compare flow numbers and ask other "EXPIRIENCED" members on this board about what they think of those heads. But if you are trying to save "A" hundred bucks, then you get what you pay for. Good luck with your build...
case closed here guys
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
Search is broken as I said.
I honestly couldn't find any threads about the Patriot heads being bad.
What is it you see has being a "better option"?
#38
LS6 Stage 2.5
$1599.00 Using customer Supplied LS-6 castings
Add $800.00 for LS-6 Cores
While TSP is
Your Price
Base Price/ea.
$1,209.99
$1,134.99
Your Price: (customized)
$1,134.99
#39
http://texas-speed.com/shop/item.asp...d=134&catid=40
1424
tea stage 2
$1745.00 With new GM 799 cores While supplies last.
Based on the flow charts provided the stage 2.5 actually flow less than the stage 2 if you look at it. The only advantage is oversized valves. Comparing apples to apples so to speak is the prc 2.5 vs tea 2.
1424
tea stage 2
#40
1424
tea stage 2
1424
tea stage 2
If I were building my entire motor I'd go with a completely different cylinder head.
