414 with 72cc heads compression
Old Feb 16, 2010 | 11:48 PM
ajohn302's Avatar
Default 414 with 72cc heads compression
can anyone give any info on a 414 iron block with -4cc dish with 72cc heads with gm stock head gaskets. what would be approximate compression ratio? do i need smaller cc heads? i would like to run pump gas. sometime run a 150 shot.. any help would be appreciated.. john
Old Feb 17, 2010 | 08:36 AM
slow trap's Avatar
11:0 scr give or take alittle. with the right cam 93 pump gas will be more than enough.
Old Feb 17, 2010 | 09:14 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Yea, that's around 11:1 but will vary depending how far in or out of the hole your pistons are, what gasket thickness you run, etc!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Feb 17, 2010 | 04:10 PM
ajohn302's Avatar
thanks guys!
Old Feb 17, 2010 | 04:29 PM
XtremeDime's Avatar
It all depends on your tune! Im assuming youre staying N/A aside from that 150shot?
