AFR heads?
Old Dec 27, 2003 | 03:15 AM
98 T/A raptor's Avatar
Default AFR heads?
I am looking at getting a set of afr heads and I am trying to figure out what to get. What is better 225cc or 205cc? Would 1.85 rockers be to much? What about a smaller combustion chamber like a 62cc? I am still gonna drive it on the street.
Old Dec 27, 2003 | 03:50 AM
jrp's Avatar
jrp
SN95 Director
well what cam are you going to run and what are your goals for your car? we all know afr's reputation but i'd wait till i see tangible numbers when they come out.
Old Dec 27, 2003 | 05:47 AM
I want about 550 hp with heads intake cam and bolt on's. It will be about april before I do anything so I can wait I was thinking of getting a custom cam. The only opinion I have gotton is from mustang guys.
Old Dec 27, 2003 | 06:07 AM
jrp's Avatar
jrp
SN95 Director
550rwhp or flywheel hp? i can tell you, you wont hit 550rwhp with any kind of combo on stock cubes, even on a solid roller setup i think thats pushing it. flywheel hp is possible with a very stout cam, full bolt ons and some stage III type heads with an m6.
Old Dec 27, 2003 | 07:44 AM
Slowhawk's Avatar
LS1Tech Sponsor
Your 550hp is a little far fetch.Try 440rwhp if you want to daily drive it,unless your doing a Stroker.
As you know AFR's are not out yet.For stock cube you'd want the 205's..
Old Dec 27, 2003 | 08:23 AM
sr71bb's Avatar
The 205's are actually reccomended even for strokers up to around 400 CI. Beyond that the 225's would be the ticket. Don't try and run more than 11:1 compression on the street because the overall quality of 93 octane gas won't support much more than this without the engine experiencing detonation and knock retard. Look at the chart in the begginning of this section for references on what chamber sizes result in the different compression ratios.
I too would wait to see just how good these AFR heads are. You could quite possibly get more bang for the buck with TEA or Patriot.
Old Dec 27, 2003 | 01:21 PM
99 Black Bird T/A's Avatar
At $1595 as cast bare ie no valves etc for the 205cc, I tend to think sr71bb makes a very good point. However, after TEA, MTI, Absolute & others develop new porting & valve jobs for the AFR's that will be the time to considering them IMO.
