Trying to figure out my CR (HELP)
Head CC volume vs Compression Ratio and according to the 5th post down .005" differnce in the gasket or milled off the head will land me 1cc difference in the combustion chamber. I did some math on my setup and wasn't sure if I was doing it correctly so here it goes:
0.053" stock head gasket
-.040" New head gasket
0.013" difference in gasket height
+.030" which is what I am having milled off the heads
0.043" which is the total height taken from the combustion chamber
then .043/.005=8.6
Which would mean that I am taking a total of 8.6 cc's out of the combustion chamber?
That just doesn't seem correct to me because that means my combustion chamber would be 58.07 cc's. If I did it correctly awesome.. if not, tell me how much of a dumbass I am with the corrections.
Thanx
If you want to find out how many cc's you remove with the head gasket you need the thicknesses and ID of each in centimeters. Then calculate the volume of the cylinder of the differing thicknesses and subtract the results. It would be alot easier to just download a CR calculator and enter the figures though.
I came up with 6.8 total cc's removed.
