PRC 237's ?
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Good luck guys and please keep us posted with the numbers..
Blue99fbody it took 3 weeks for PRC 237 heads to arrive to Saudi Arabia I'm sure you'll recieve your in less than two weeks
I will post some results from my friend's TSP 408ci PRC 237 and TSP Gaint very soon..
However, on the last re-torque a crack was discovered the the casting as it pissed water all over the place. That deficiency has been corrected according to the guys at TSP and they sent another set of heads to LME for me. If you guys are waiting on boosted results, it'll be sometime in early 2012 before I can do that for you due to my being deployed currently.
I'd still like to know the deck thickness of them. Guys that are going to run high boost NEED the increased deck thickness and if these heads don't have .750", then I'll scratch them off the list.
