LS1 Oil looks like chocolate Idea?
I think i have antifreeze in my oil, i just bought this engine ....my bad i should have checked better ?
What is the cause of this in a LS1 any easy way to figure this out ...i am thinking head gasket ..where are the commen leak area's ?
I drove the car before buying the engine it ran fine .
HELP
HELP
HELP
HELP
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
Yes that is correct ....is this common and does this wipe out the bearings ...or are LS motors able to handle this without damage?
anyway to test before replacing head gaskets ..should i use gm gaskets and replace the head bolts ..i seen aGM kit to 129 ...all gaskets and bolts.
You will need to replace the head gaskets. gm MLS headgaskets will be fine. You will also need new head bolts.
This might be overkill but it might be a good idea to replace some extra gaskets while your in there. Its got everything you will need and more.
http://sdpc2000.com/details/scoggin-...ter/kitsd28902
also, no motor should be ran with a bad headgasket. It will destroy the bearings. It will probably run ok at first but after awhile it wont be running at all. Fix this immediately unless you want to be buying a whole new motor.
Don't go tearing it apart yet it's not conclusive to say my oil looks or my coolant looks....
You can do a cranking compression test and a leakdown test to find out if there's really a problem. Do a search on this site or google to learn how to do those tests.
