EPS cam in 5.3??
I'm looking at their 222/226 113lsa cam............ sounds like a good cam. its listed under ls1.
Would it wrk good in a 5.3?
haven't seen much dyno results for me to pull out card and order one.
thanks,
dennis
thanks,
dennis
jeff skinner(eps) started thunder racing a long time ago id go with one fo their cams a 224/224 would probably be great in your truck im not sure though i know most about ls1s and from what i know just het you 5.3s milled ported and polished would work way better than ls6 heads
id go with either thunder racings "Split Pattern" - 224/227 .563/.569 114 LSA For nitrous and supercharger applications. This cam will check in the 226 range on the exhaust lobe. 2200-6800 RPM Power Band. Excellent mid-range & high RPM power. Automatic cars require computer tuning and it is recommend for optimum results on manual transmission cars. Due to the fast ramp rate of this camshaft, the use of 1.8 rockers is not recommended.
or this one that thunder advertises toward the bottom or their cam page for the trucks
Comp Cams LS1 Camshaft - 219/ 227 .607 / .614 112 LSA, Excellent torque with a very broad power band. Great for street performance and drivability. RPM range of 1500 to 6700.
