317 Head swap
Old Feb 23, 2010 | 12:00 PM
kobraa's Avatar
Default 317 Head swap
I'm swapping my stock 806 heads on my 98 TA for some remanufactured 317's. Would the 5.7 L MLS gaskets be okay to use? I'm doing a basic stock rebuild with some bolt ons.
Old Feb 23, 2010 | 12:13 PM
Ford_Assassin's Avatar
I am sure you already know this, but you are going to lose a decent amount of compression running 317 heads with stock LS1 pistons.
Old Feb 23, 2010 | 12:56 PM
King Nothing's Avatar
Originally Posted by Ford_Assassin
The stock 5.7 MLS gaskets will be fine.
^ yep you are
Old Feb 23, 2010 | 01:01 PM
kobraa's Avatar
I'm aware...but the heads were milled down a bit so I wont lose too much. Plus this gives me the opportunity to slap on a blower or nitrous system if I ever want : )
Old Feb 23, 2010 | 01:21 PM
BadgeZ28's Avatar
Nope. Use the 6.0 mls gasket with the 317's
Old Feb 23, 2010 | 01:40 PM
MonmouthCtyLS7's Avatar
Should have mentioned that in the 1st place
Old Feb 23, 2010 | 02:44 PM
kobraa's Avatar
I guess...I was more concerned with using the correct gaskets tho
Old Feb 23, 2010 | 05:40 PM
gearhead1186's Avatar
Old Feb 23, 2010 | 05:53 PM
User_name's Avatar
I called Texas Speed and they told me to use 6.0L gaskets.
Old Feb 23, 2010 | 06:00 PM
69LT1Bird's Avatar
The combustion chamber width is the issue, if the gasket is too small it will hang out or be too close to the edge of the cylinder and it will become a hot spot or get burned. So, use 6.0L headgaskets.
Old Feb 23, 2010 | 06:02 PM
1slowfbody's Avatar
stage 2.5 LS6 heads work great for blowers also
Old Feb 23, 2010 | 06:39 PM
PowerShift408's Avatar
Definitely 6.0 gaskets.
Old Feb 23, 2010 | 08:26 PM
Okay, so lets flip this. What stock MLS gaskets to use if you are running 5.3 heads on a 6.0?
Old Feb 23, 2010 | 08:31 PM
69LT1Bird's Avatar
There really is not difference, if the bore of the cylinder is the biggest opening that's the head gasket to use.
