piston question
Old Feb 23, 2010 | 04:11 PM
DarknessHunter's Avatar
Default piston question
can i use stock pistons in an iron 6.0 with a 4" crank
Old Feb 23, 2010 | 04:18 PM
Armageddon's Avatar
...with cheese.
A 4" stroke is going to alter your rod length from 6.098 to 6.125. I'm not sure how exactly this would effect the piston but I personally would not run them.
Old Feb 23, 2010 | 05:11 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
No, the stock pistons have a compression distance of around 1.33x". With the 4.0" crank, even using the short stock rods, your piston will then be about .190" out of the hole. That's not a good situation. You definitely have to order a piston made specifically for the crank and rods you're running.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Feb 23, 2010 | 08:04 PM
cool thanks guys
Old Feb 24, 2010 | 01:04 AM
5150.4.67's Avatar
Wooooohooooooo!!! Your killing me!
