Going for a big cam..which one?
Old Dec 28, 2003 | 04:35 PM
ChevyWeatherman's Avatar
master of the "jack"stand
Question Going for a big cam..which one?
I've done a lot of research on this, but can't decide. I am staying stock headed for a good while, but I still want a monster cam. I kind of have my heart set on the TSP 231/237 112 lsa, but probably because I can find the most info on that one. What about the G5X-2 and 3? I know these are harsher on springs, but with Crane duals would I be OK? I am also staying with the stock 3.42s until they break. The powerband on the TSP seems pretty good, even for street driving. I will be doing a mix of street/strip/autoX. Down low as long as it pulls as hard as stock I'll be happy, but 2700-3000 on up I want it to scream. I have heard SouthFL02SS's clip of him hammering it in gear and I can hear the car bog a bit before it comes up on the cam in 2nd gear, I'm guessing I would see a similar thing with the X2 and X3 cams? Are there any other big cams to consider? Basically I want your guys' opinions on why or why not to go with the 231/237 as opposed to another. I don't want to regret not going bigger, but I don't want a cam that isn't driveable powerband-wise on the street.
Thanks..
Old Dec 29, 2003 | 05:09 AM
jrp's Avatar
jrp
SN95 Director
out of thoses i'd go with the tsp231. just do a search or look on the first or 2nd page and you'll find at least 5 threads pertaining to the x2 and x3.
Old Dec 29, 2003 | 06:50 AM
gomer's Avatar
I'm running the TSP231/237 with my stock 3.42's and it isn't too bad. I can cruise along at 55 or 60mph in 6th gear and it doesn't buck. You MUST realize that there is NO way you can run a cam this big comfortably with a stock tune. Jason from TSP did my tune via "mail order" and has it pretty close, it still lacks a little on "tip in" but all in all, I'm very satisfied with the driveability of it..heck my wife even drives the car now and then and doesn't bitch about it!!
Old Dec 29, 2003 | 06:54 AM
Joe "Preachers Sheets" DIESO's Avatar
Humanitarian
Gomer I don't think your accurate with that statement. I have a close friend who runs a TR 236 cam and it drives and idles just like his 224.
If the tuner can't tune; thats another story.
Old Dec 29, 2003 | 07:50 AM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
Originally Posted by ChevyWeatherman
...I have heard SouthFL02SS's clip of him hammering it in gear and I can hear the car bog a bit before it comes up on the cam in 2nd gear...
Thanks..
How much that has to do with the cam's powerband I dunno. I'd think it's more to do w/ me letting up a little on my right foot to regain traction.
Old Dec 29, 2003 | 12:10 PM
DAPSUPRSLO's Avatar
You could always try mine. 230/236 107lsa 107icl 576/573. It doesn't buck in sixth gear but it doesn't pull much in sixth gear either. I do have 4.11s though.
Old Dec 29, 2003 | 02:10 PM
That makes me even happier..that thing just sounds mean when you hammer it.
Yes, I realize that I will need a tune. SouthFL, are you happy with how much it lopes on the 112 LSA? Sounds pretty good to me.. That 107 LSA is getting pretty crazy, but cool.
I'm thinking I'll stay away from the G5s because of the spring issue. I'm sure that they are ok now (REV springs) and I know that they do break, but I think I like the idea of the big cam on the XE lobes for now. Just peace of mind about the springs I guess. I'm figuring that the X2 and X3 would only be giving me 5-15 more HP anyway with stock heads.
What is the ICL on the TSP 231.237?
Thanks for the help guys..keep going!
Old Dec 29, 2003 | 02:14 PM
gomer's Avatar
The TSP231/237 is a 112lsa with 2degrees of advance ground into it, so it is a 110 ICL
Old Dec 29, 2003 | 04:44 PM
Thanks gomer! Any bets on how long my stock clutch will last;D? There are 7000 miles on it..
Old Dec 29, 2003 | 04:48 PM
gomer's Avatar
I replaced my stocker at 3,500miles. But I had a TR220 and a set of stage II 5.3 heads by that time. When it comes time, check out the spec stage III.. I have nothing but good things to say about mine. Be sure you buy a new flywheel with it and don't try to reuse your stock one, that's the key to making sure it doesn't "chatter"
Old Dec 29, 2003 | 04:53 PM
SPANKY LS1's Avatar
I don't think the TSP 231/237 is going to be signifigantly easier on springs than an X2 or X3, definitely not enough to justify the power loss, IMO. Giving up 5-15 rwhp on a cam only car is signifigant, especially for no more $$$. At 400 rwhp and up, 5+ rwhp gets harder and harder to come by.
Get the X2 or X3 on 114. I have heard the X2 on a 114, and it was less radical (idled better and smoother) sounding than my 230/224 was when you heard it.
Shawn
