is this an ls6 intake?
Old Feb 24, 2010 | 09:22 AM
GARAGE_BUILT_Z28's Avatar
Question is this an ls6 intake?
swapping my old ls1 intake and would like to know if this is a real ls6 intake thanks.
http://cgi.ebay.com/ebaymotors/GM-LS...mZ190369280565
Old Feb 24, 2010 | 09:34 AM
nncfan8's Avatar
yes b/c the bottom is completely flat it is an ls6. ls1's have a hump on the bottom.
conan's Avatar
Yes it is. The flat bottom and no egr hole is the ls6.
Ls1 intake on left, Ls6 intake on the right...
http://www.ls1howto.com/howto/geniii...//IMAGE009.jpg
Old Feb 24, 2010 | 09:35 AM
Jon@Texas-Speed's Avatar
Yes sir. Part number is old LS6 part number.
Jon
Old Feb 24, 2010 | 09:40 AM
ok thanks guys...jon i'll be calling you soon for the pacestters LT's and y-pipe
Old Feb 24, 2010 | 09:46 AM
also ive been reading about if your doing a head/cam swap you should upgrade your stock injectors my car is a 99 with the 28# injectors will it be better to upgrade to these or stay with my stockers
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
Old Feb 24, 2010 | 09:48 AM
01ssreda4's Avatar
SVO 30s would be good for you.
Old Feb 24, 2010 | 09:51 AM
ok..cool this is my first z28 and my first time doing a h/c swap and i want to make sure i do everything right..how much do you think my ls1 intake and heads sale for the heads are 806 casting
Old Feb 24, 2010 | 10:31 AM
hcb1700's Avatar
yes it is.
Old Feb 24, 2010 | 10:49 AM
01ssreda4's Avatar
put em on ebay and see what they go for...
Old Feb 24, 2010 | 11:25 AM
the_merv's Avatar
Do the LS1 Intakes without EGR have the Hump still?
Old Feb 24, 2010 | 02:30 PM
01ssreda4's Avatar
bottoms always tell. As corvette and SLP versions float around breaking the standardized rules, the bottom is the sure fire way to tell them apart.
Old Feb 24, 2010 | 03:01 PM
00pooterSS's Avatar
LS1 intakes without EGR are LS6 intakes, so no they do not have the hump.
Edit: I dont know about vettes and EGR so there could be some bastard intake in there from the early vettes, but F-body intakes that dont have EGR are LS6 intakes, and do not have the hump. Earlier I was only thinking in F-body terms, I dont know about the non EGR LS1 intakes.
Old Feb 24, 2010 | 04:14 PM
01ssreda4's Avatar
didnt the first vette ls1 intake not have egr??
Old Feb 24, 2010 | 06:03 PM
02_Z28_G's Avatar
ok so how can you tell if you already happen to have an ls6 intake w/o removing it to look underneath?
Old Feb 24, 2010 | 06:20 PM
01ssreda4's Avatar
part number
Old Feb 24, 2010 | 06:36 PM
mchdg86's Avatar
No C5 vette ever had EGR. So the best way to tell is to look at the bottom or run the part number.
Old Feb 24, 2010 | 09:45 PM
00pooterSS's Avatar
So does a Non EGR LS1 intake exist? Would the early C5's be the same intake as a LS1 with the hump on bottom but no EGR provision?
Old Feb 24, 2010 | 09:48 PM
TX02ramair's Avatar
Like the rest of the guys said the best way to tell if it's a ls6 intake is the flat bottom... some c5 corvettes did come up with a ls1 no EGR intake...
Old Feb 24, 2010 | 10:01 PM
mchdg86's Avatar
All C5s from 97-04 didn't have EGR.
