ls6 346ci vs. 383ci
1slowfbody - Sounds pretty sweet. Best of luck with your build. I always say Do what YOU want and ignore all the negative responses. Because in the end you are the one living with it, not them. As long as it is mechanically sound and safe then there is no reason to change your goals to please someone else.
3 or 4 people actually know what i'm doing and even some bits of info are unknown to them lol
![Secret](https://ls1tech.com/forums/images/smilies3/secret2.gif)
I have a 383 W/Callies parts, the displacement is nice but it's the piece of mind that you can spin the motor hard under boost. Also there is a built in safety margin if for example you encounter some detonation from bad gas or super high intake temps. You can't always tune those out if they're just random events.
