What's a P0420 code?
Old Feb 25, 2010 | 12:58 AM
415Z28's Avatar
Default What's a P0420 code?
I had this code and changed the PCV and it's still coming upDo I need to clean the tubing?
Old Feb 25, 2010 | 01:58 AM
Mumbles's Avatar
I get this code from time to time as well.
Isn't it Catalyst Efficiency Low Performance, or something to that effect.
I started getting mine when I installed LT's and my catted Y-pipe. I figure the cats in the new Y-pipe aren't as efficient as the factory cats. (They are much smaller, so it makes sense.) The Y-pipe also had bungs for the rear O2 Sensors so I installed them. I suppose the O2's are reading more emissions and throwing the code.
When I finally get my Mail-Order-Tune I'm sure the code won't show up again.
Do you have LT's? If so, I'd say its time you consider getting a Tune as well.
Old Feb 25, 2010 | 02:10 AM
craig382ci's Avatar
Done a search on it, go to this http://www.obd-codes.com/p0420
Old Feb 25, 2010 | 02:17 AM
Damian's Avatar
LSX Mechanic
Google is your friend sir.
It's a code telling you one of your cats isn't working properly, or at all.
Old Feb 25, 2010 | 09:16 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
I've seen the code very recently on my personal car. I figured it was a cat, but I was wrong! I actually had broken a small vacuum hose in the engine bay when I was changing my spark plugs. I fixed that vacuum leak, cleared the code, and it has never come back.
Moral of this story: It could be a wide variety of things causing the code...don't assume it's a cat just because it says "catalyst" in the description. I could have spent $100 or so trying to fix the code, but instead it cost me under $1.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
