Did they ever put the ls6 in the camaro.
Old Feb 28, 2010 | 10:11 PM
baalic's Avatar
Originally Posted by garygnu
the ls6 block is worth a couple more hp,the windows cast into the lower section of the block help equalize the crankcase pressure.
tell that to the people with the LS6 blocks that Dyno the exact same as those with the LS1 Block...
Old Mar 2, 2010 | 04:55 PM
spacejunkiehsv's Avatar
Question
I was doing some searching and found this thread. So, a stock 01 or 02 WS6 has how much of a power advantage over stock 98?
I will spend most of my money on road course driving events (not racing). So, I will probably never get more power than 400 at the wheels. I'm thinking that I shouldn't let the whole "LS6 intake and block on 01+" issue influence my purchase very much. Should I?
Old Mar 2, 2010 | 05:17 PM
bww3588's Avatar
no, an LS1 is an LS1 is an LS1. the *only* advantage the 99+ cars have over the 98's is the head design and the blocks on the 99+ is a little more forgiving to a hone. from what ive been told is a 97-98 LS1 cant even be honed to 3.903.
also, just to clarify, some 99's came with 241 heads as well.
Old Mar 3, 2010 | 05:44 PM
cali_bear2003's Avatar
well my 350-370hp was for the LS6 engine, not for the LS1 engine....Basically referring to the Z06 Corvette...
Yes, I understand this as being dyno information for the c5 z06 vette, but he might not and this is a camaro topic. No disrespect intended, but it might not have been clear to him....sorry.
Old Mar 3, 2010 | 09:36 PM
Steve99's Avatar
8th digit of the VIN. G is LS1, S is LS6.
Old Mar 3, 2010 | 09:37 PM
bww3588's Avatar
you wont find an "S" for the 8th digit of the VIN on a Camaro.
Old Mar 3, 2010 | 09:45 PM
Steve99's Avatar
my edit didnt save i figured they never put the LS6 in the camaro, but if there was one it would be an S for the 8th digit, but im sure they never did.
Old Mar 3, 2010 | 10:35 PM
2manycars's Avatar
I think he just did...
Old Mar 5, 2010 | 10:40 AM
Bizzles's Avatar
LS6 Blocks have the "D" shaped oil passages too.
Old Mar 5, 2010 | 10:45 AM
Is that better for heat transfer? Why the D shaped passages?
Old Mar 5, 2010 | 11:00 AM
Bizzles's Avatar
I know the the curved part of the D points down so there's less resistance to flow vs. a square port (ls1). Plus you gotta think chevy was building this motor knowing it was for the Z06 (more of road racing application than the Ls1) Not sure exactly why they did it lol but i know its there b/c I got into an argument w/ some1 who swore an LS6 block was exactly the same as an LS1
Maybe the older dudes can shed some light on the advantages of the LS6 Passages?
Old Mar 6, 2010 | 10:06 PM
  #32
baalic's Avatar
10-15hp with the 01-02 fbodys vs 98-99 due to LS6 intake....
Old Mar 7, 2010 | 07:59 AM
  #33
allbaugh_04's Avatar
True they have the LS6 intake, BUT wrong because the 01/02 came with a much smaller camshaft. So they didn't have much more power, if any at all.
Old Mar 7, 2010 | 09:49 AM
  #34
Doesn't a "much smaller camshaft" contribute to much less wear and tear on the valvetrain components? If the answer is yes, then how many more miles do you think that would be worth on a stock engine?
Old Mar 7, 2010 | 01:16 PM
  #35
baalic's Avatar
actually the smaller cam gave it a little more punch on the low end but nothing in the high end, as in, no max hp/trq gain, just a little bump in the bottom end... at least according to GM...
Old Mar 7, 2010 | 01:37 PM
  #36
Fb0dy0nly's Avatar
Dont you think that if there was a WAY better block or "ls1" out there to have, people would be talking about it, or it would up on this site in a hundred posts?!? Everyone knows that late late 00'-02' fbody ls1's were a lil better than the early ones as MOST engine are, due to more efficient designs added from the first years, etc. With the added Ls6 intake and possible block, id take one over the early years, plus, 98 computer is a pain in the *** to tune.
Old Mar 7, 2010 | 01:42 PM
  #37
baalic's Avatar
who's argument are you fighting for here???
Old Mar 7, 2010 | 01:43 PM
  #38
WSsick's Avatar
as someone already said, an LS1 is an LS1 is an LS1. NO fbody came with an LS6 engine, cam, or heads stock. The LS6 intake and the bigger camshaft cancel each other out so that makes them pretty damn near equal. the only LS1s that are supposed to be weaker are the 98s, (weaker rod bolts i believe) but if youre building the motor anyways, the even that doesnt matter. id worry more about mileage and abuse of the engine than which has a biiger cam/ls6 intake. An LS1 is an LS1 is an LS1 is an LS1.....
Old Mar 7, 2010 | 05:38 PM
  #39
Well it has a bit less duration and lift, but I doubt it's enough to make any kind of major difference. Usually something else would break first or wear out. I haven't heard many stories out there where the engine has broken a rod at stock power etc.
I'm curious to know how long the stock engine would last on a regular basis without modification and proper maintenance.
I'm willing to bet these cars (die) 9/10 because of a accident
