double roller fitment question
Old Feb 28, 2010 | 10:08 AM
irocbmx's Avatar
Default double roller fitment question
I am going to be doing a head and cam swap on my 2002 SS, I got a rollermaster double roller timing chain, TSP ported ls6 oil pump, and a powerbond u/d pulley. My question is, will i have any serious clearance issues between the oil pump and the front timing cover? I heard you have to do some grinding with a dremel, is that all? Also will my powerbond pulley need to be machined to work with the double roller timing chain?
Old Mar 1, 2010 | 05:20 AM
irocbmx's Avatar
TTT. Anybody have experience with these parts?
Old Mar 1, 2010 | 10:02 AM
conan's Avatar
I have a rollmaster double with a tsp ported oil pump and everything fits just fine. I installed everything when I was building my forged moter and I put the timing cover on and rolled the engine over by hand 20/30 times. Then I removed the timing cover to make sure the chain wasn't hitting the timing cover. Every thing was good so I put the cover back on and was good to go.
Old Mar 1, 2010 | 10:12 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
With that combo you should be fine without having to clearance the cover and no milling on the balancer. But, like Conan said above, it's always good to check everything to ensure proper fitment!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Mar 1, 2010 | 10:20 AM
conan's Avatar
I forgot to add I use a ATI super damper crank pully and I haven't had to mill the hub to fit deeper into the engine due to the oil pump shims.
Old Mar 1, 2010 | 12:35 PM
sscamaroburn02's Avatar
i have the double roller and tsp ported ls6 pump and no issues at all. everything is fine after a year now.
Old Mar 1, 2010 | 03:37 PM
irocbmx's Avatar
Thanks for all your replies, I'm glad to hear that this combination will work, I searched for over an hour the other day, and kept finding post that went back and fourth about the double roller. I will defiantly double check the fitment though when i install it.
