Arp Rod Bolts
i still wouldnt trust not resizing them. just run an oversized bearing and live with the peace of mind that your short block is put together the way its supposed to be.
just because it works, doesnt make it right. and it doesnt work in everycase.
sorry i dont like to fill people's heads that "good enough" or "it worked for me" is the correct way to do things.
ill revert to one of my previous posts,
i kick my girlfriend in the **** and she cleans, but that doesnt make it right.
just because you know how to do things, and many other people do as well, doesnt mean everyone knows how to do them.
That is not the only difference and regardless whether you swap ARP's or Katech's they should be done one at a time because you don't want the cracked rods to move.
If you put the ARP's and Katech's side by side the ARP's are noticeably larger. The Katech's are nearly stock sized and weigh within a few grams of OEM. The ARP's are larger and heavier and according to some this causes different clamping properties which can cause the rod distortion some attribute to ARP's.
I don't know whether this is valid or not but know if I change mine in my stock bottom Katech's will go in for no worries. On a rebuild I will save a little coin and go ARP...
