c5r head port work
Old Dec 30, 2003 | 08:49 AM
hugger427's Avatar
good thread, what would the $$$ range be for C5-R heads????
Thanks,
Ron
Old Dec 30, 2003 | 08:52 AM
Mr Powell's Avatar
$1200 or so a bare head, each. Then you need Springs, Rocker Arms, Valves.. All non-standard LS1 parts.
A Intake will cost right around $3200 or so, and its about $5k for the Kinsler setup (individual Horn shaped throttle bodies).
If you put this on a flat top piston it will make somewhere in the 15:1 as far as compression goes. A -17cc Piston I think we figured would make right around 11.5:1 or 12:1.. I've looked at doing this a few times lol!!
Old Dec 31, 2003 | 10:14 PM
2001CamaroGuy's Avatar
has anyone made an intake for C5R heads that will fit in an F-body?
Old Jan 1, 2004 | 01:07 PM
restoman45's Avatar
when i talked to ARE a while back, they had one that fit they said, but u may need at least a aftermarket hood of some sort...but thats the reason the intake will cost so much money...its more of a one off deal cause the demand is soo low.
