pulling engine
Old Mar 3, 2010 | 01:56 PM
pauls99z28's Avatar
Is there a writeup for the dropping the engine??? sorry for the hijack
Old Mar 3, 2010 | 06:25 PM
Inspector12's Avatar
TT-TECH Veteran
I helped a guy who was supposed to be doing one etc... But I never followed up to see if he actually did.
Old Mar 3, 2010 | 07:36 PM
conan's Avatar
Originally Posted by 350 WS6
now for the wiring harness, did you all just disconnect everything and throw it on top of the engine or wat?
I left my harness in the car twice now. The 3rd time... (and there will be ) I'm going to try pulling the harness with the engine, It is a little bit of a pain in the *** unpluging every conection on the moter and trans.
Harness in car... http://mycarpics.shutterfly.com/204
I also brake the bottom ball joints and leave the strut, spinde, caliper, and upper A arm in the car. The lower A arms stay on the K member.
http://mycarpics.shutterfly.com/208
http://mycarpics.shutterfly.com/209
Old Mar 8, 2010 | 03:03 PM
johnzss's Avatar
I will be pulling my motor out within the next couple of days. For the experienced folks... wondering myself, where on the motor are you guys attaching the cherry picker to? its a m6, is it best to remove the tranny first, pull it out. then continue pulling the motor out or otherwise? same with the LT, remove with engine or remove first? (pacesetters) *sorry for highjacking. atleast were still on topic lol
Old Mar 8, 2010 | 03:34 PM
lmt0705's Avatar
johnzss, go thru the bottom if you have the ability in your shop and leave the harness on the motor. its rediculously easy doing it this way. I pulled the motor/trans out the top once and I made a plate that bolted in place of the intake manifold but trust me its WAY easier out the bottom
Old Mar 8, 2010 | 03:37 PM
johnzss's Avatar
oh i believe you, i dont think i have enough clearance in my garage.. anyone know how high you have to get the car in the air in order to drop the motor/trans from the bottom?
Old Mar 15, 2010 | 10:08 AM
350 WS6's Avatar
Thanks everyone for your help. it was very helpful. i ended up pulling out of the bottom and it was a breeze. it took 2 1/2 hours to drop it and i had it 100% complete the next weekend. so thanks again. it went well and fired right up. the new engine ended up haveing a cam in it!
Old Mar 15, 2010 | 12:07 PM
conan's Avatar
Congrats man, have fun with the new engine.
Old Mar 15, 2010 | 02:17 PM
pauls99z28's Avatar
Congrats! now i need to try that out myself.
Old Mar 15, 2010 | 02:22 PM
350 WS6's Avatar
its really not that hard. all there is is 3 big bolts on each side of the k member and once when you get those out it just drops out. and i think i had mine at least 3 feet off the ground. and also there is 4 major ground wires you gotta worry about. there is 3 on the back of the heads and then one that goes in the block. also i dropped everything at once with out taking the trans off.
Old Mar 15, 2010 | 02:27 PM
pauls99z28's Avatar
Ok thanks. I guess it just sounds and looks hard. ive been holding off doing it for awhile now too. but i might just do it here in the next couple weeks. just waiting for some parts.
Old Mar 15, 2010 | 02:35 PM
  #32
350 WS6's Avatar
the hardest thing is just making sure you have the whole wiring kit disconnected. and if you are dropping the engine and the trans put a jack stand under the trans or if you have another jack.ummm take the radiator and a/c out first, and then start disconnecting. you have sensors begind the motor. oil pressure sending unit, intake manifld, 2 on the trans and ten there is one more but i dont know which one it is. and then of course you have the ground wires.
Old Mar 24, 2010 | 06:04 PM
  #33
TT-TECH Veteran
Good job on your motor swap! I take the wiring with the motors its a lot easier. Just take the passenger kick panel off and unplug the two conectors (White and blue) remove the PCM and the harness comes out and the unplug the three or four connectors on the passengerside fender well the one wire on the fuse panel on the front drivers side of the car and a 10mm ground on the driverside frame rail.
Old Mar 24, 2010 | 07:42 PM
  #34
johnster's Avatar
pulled mine out the top 2 times ant that bad if u pull the intake and accessories it ant bad at all
