EPS Cams
Old Mar 4, 2010 | 11:44 AM
Musthaveboost's Avatar
Default EPS Cams
Iv been looking at Cam's for sometime now. I heard Patrick G was working with theis cams making good power without being as hard on the springs.
http://www.engpwrsys.com/index.php?a...d&productId=10
234/246 .602/.607 111 LSA
Right now my mods a Lid and Catback w/cutout.
Car is an 02 WS6 M6
Looking to get a set of KOOKS longs tubes and Y pipe before a cam.
Also getting a Rebuilt Trans, and Very possibly a 12 bolt. What gear would i want?
Old Mar 4, 2010 | 12:09 PM
MikeG's Avatar
That cam should make great power. I've heard nothing but good things about EPS cams. I'd go with a 9" with 4.30s.
Old Mar 4, 2010 | 12:19 PM
RARON455's Avatar
I am currently waiting for my 2nd cam that is going in my 383, I have had two custom cams made by EPS (Geoff Skinner) IF you are wanting a custom cam, There IS NO ONE BETTER to pick one for you PERIOD.. My stock shortblock and PRC 5.3head combo put down 463 HP with his custom cam for me, I cant wait to get my stroker finished and see what the new combo puts down. SUPER guy to deal with, I wouldnt go anywhere else.
Old Mar 4, 2010 | 03:05 PM
TooLateVTEC's Avatar
What trans is in the car? Is a a DD, streetcar, race car?
DD or streetcar with occasional racing, 3.73.
race car, 4.10-4.30
4.30 is too much for a streetcar with an auto, but would be more livable with a 6 speed.
Old Mar 4, 2010 | 03:29 PM
00MaroonZ28's Avatar
Holy exhaust duration. I think you might want to tighten that to make it more streetable and easier to tune.
Old Mar 4, 2010 | 05:21 PM
garygnu's Avatar
there is a thread about this cam lobe design in the dyno section.
Old Mar 4, 2010 | 05:48 PM
69LT1Bird's Avatar
That cam is just fine, very streetable and no problem tuning.
Old Mar 13, 2010 | 06:02 PM
Would i really need to Rev this thing all the way up to 7200 RPM???
Kinda iffy on running a stock bottom end reving that high.
Old Mar 13, 2010 | 06:29 PM
Squirts11's Avatar
I wouldn't think that would be wise considering you have stock rod bolts.
Regarding EPS lobes, my PatG cam is an EPS lobe, and although it was a very mild grind (specs in sig), I picked up 45rwhp with it.
Old Mar 13, 2010 | 06:53 PM
Iv been looking into putting Katech rodbolts in.
Maybe i should get a custom cam, just a bit smaller.
Old Jun 28, 2010 | 01:21 PM
BFarrier's Avatar
i run 3:73 in a 12 bolt and in looking at the eps 222/226 cam on 114lsa cause i live in cali and those gears for being DD regardles wakes the car up better than the stock ratio
Old Jun 28, 2010 | 03:51 PM
99Bluz28's Avatar
Lightbulb
Just give Geoff a call, tell him your wants/needs from you car and he'll spec you cam.
My bad, to many calls I guess.
Old Jun 28, 2010 | 10:54 PM
SOMbitch's Avatar
Fill out the sheet on EPS webpage and Geoff will call you with ??'s to nail things down. I have no experince with Geoff"s cams before now but we talked for AT LEAST 30 mins before he specced my 403 cam....The SB is still being built so I am a ways away from reporting on the results.... He spent a great deal of time w/ me asking ??'s and the time he spent w/ me was almost unheard of nowadays. Great guy and his results posted so far speak for themselves. I will will post my results when things get together but between HKE , Geoff & RPM Motorsports it should be strong.....
Old Jun 28, 2010 | 10:57 PM
Paint_It_Black's Avatar
That's the cam I am running, except I got it on a 110+3 because I wasn't worried about fly cutting.
Old Jun 28, 2010 | 11:02 PM
SOMbitch's Avatar
Ya talking the 222/226 cam??? He specced a 238/250 113+3 cam for my 403??? Heads are tweaked TFS 220 as cast that flow 320+/250+ ....
Old Jun 28, 2010 | 11:25 PM
No, the 234/246. It's about the same as his max effort cam for the 346, which is a 236/248 110+3.. but that one won't fit without cutting, and is on XFI lobes. I wanted the EPS lobes so we compromised.
Old Jun 29, 2010 | 12:01 AM
SOMbitch's Avatar
Gotcha.... what CI you running???
I was actually expecting slightly more duration with a little less LSA than he recommended for my setup but he knows WAAAAAAY more than me so I am sure I will be happy.... Why I never get into "what cam" threads other than a general statement....
Old Jun 29, 2010 | 12:15 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
If I ever get rid of my 228r this is the cam I will be rolling over. With 18° that is a lumpy sounding son of a gun.
Old Jun 29, 2010 | 12:28 AM
Stock bottom end, fly cut, 58cc ported 241's, just a hair under 12-1 compression.. SD tune running on E85. Tune won't be until after the 4th of july though, so I have 100 in the tank and still have the stock maf on it til then.
I remember Bret saying several times he would send cams out he specced.. and the racers would be pissed off because they thought it was too small.. but they always ran faster at the track and that's what matters.
Old Jun 29, 2010 | 09:53 AM
SOMbitch's Avatar
Sounds like a nice setup you have....
Yeah you are right about the track times too. Bigger is not better unless you have the right parts to match (stall ,gear etc...).
