Engine Smokes At Idle
Old Dec 30, 2003 | 02:03 AM
gEtyOPaPiOn's Avatar
Default Engine Smokes At Idle
2001 LS1 ....HI ENGINE SMOKES WHEN IDLING AND IT APEARS TO GET FLOODED AFTER A WHILE ? BAD INJECTORS ? THANKS
Old Dec 30, 2003 | 07:04 AM
2001 Pewter WS6's Avatar
Restricted User
Sounds like you are running too rich. What mods did you do? If it is stock then take it to the dealer if not then get it tuned..
Old Dec 30, 2003 | 07:50 AM
niphilli's Avatar
What color is the smoke?
Old Dec 30, 2003 | 07:34 PM
SMOKE IS KIND OF DARK AND SPARK PLUGS TEND FLOODED AFTER A PROLONGED IDLE .....FUEL PRESSURE IS AT 58 PSI....UMMM BUT COMPUTER HASNT BEEN REPROGRAMED YET AND ALL EMISSION CONTROLS WERE REMOVED ONLY FRONT OXIGEN SENSORS ARE CONNECTED
http://members.aol.com/getyopapion/Welcome.html
Old Dec 30, 2003 | 07:44 PM
Restricted User
Looks nice...
From the pics, I can't see an air intake temp sensor. Do you have one?
Old Dec 30, 2003 | 08:29 PM
Its There But Not Installed In The Intake Yet...could That Be The Problem ? Thank You
Old Dec 31, 2003 | 05:53 AM
Slowhawk's Avatar
LS1Tech Sponsor
If you got rid of the emmisions but didn't delete the codes,you could be in a limp mode on the computer..Also I notice your running a 382,you really need to have the car tuned before you damage the motor.
Old Dec 31, 2003 | 11:54 AM
Scalpel's Avatar
Yep, do not drive it until it's properly tuned. You can wash down your cylinder walls and ruin your rings.
Old Dec 31, 2003 | 09:11 PM
DaleMX's Avatar
He's absolutely right. Wash down kills the rings in no time.
