Oversize Piston Rings
Old Mar 6, 2010 | 07:20 AM
VLLS6's Avatar
Default Oversize Piston Rings
Hi all,
I am running 10 thou oversize pistons on my LS1 and i am finding it difficult to source piston rings for them. My bore size is 3.908 can anybody steer me in the right direction of where i can find some rings?
Any help would be much appreciated i have looked on online stores but can only find 5 thou oversize rings.
Old Mar 6, 2010 | 07:34 AM
427's Avatar
427
Total Seal should have what you are looking for.
Kurt
Old Mar 6, 2010 | 08:16 AM
VLLS6's Avatar
thanks kurt i actually checked their site and strangely enough they only have ls1 rings in the oversizes of 5 and 15 thou
Old Mar 6, 2010 | 11:03 AM
427's Avatar
427
Contact them, they have much more than what is listed on web.
Kurt
Old Mar 6, 2010 | 12:44 PM
racer7088's Avatar
You need to tell them what the radial walls are or you will repeat your problem.
Old Mar 6, 2010 | 11:40 PM
VLLS6's Avatar
I contacted Total Seal and gave them the dimensions of my ring lands and i am just waiting for them to get back to me. Would it be correct to say that the dimensions of the ring lands vary depending on the manufacturer of the piston? Just in case it is of any interest my ring land sizes are as follows:
Top Groove - 1.5mm x .153" Deep
Second Groove - 1.5mm x .178" Deep
Oil Groove - 3mm x .153" Deep
Old Mar 7, 2010 | 01:33 AM
racer7088's Avatar
Yes you are right as some use thinner radial width and lower tension than others.
