Springs and retainers
Old Dec 30, 2003 | 10:04 AM
642642's Avatar
Default Springs and retainers
I've ran into a little problem here. I order some springs and retainers from CMotorsports, the valve locks are flush with the valve stem and the retainers sit higher then the valve stem. So they sent me the wrong retainers???? I try to call them but they are moving the shop and are going to be close untill JAN 30. (The car is apart and I need it back together ASAP) My problem
The way it should be
SO does anyone know where I can get some retainers that will fit CM's springs???? Or if someone knows another way to get ahold of them instead of the shops phone??
Old Dec 30, 2003 | 10:11 AM
GWTFI's Avatar
Err, Why didn't you stop after the first one didn't look right?
Old Dec 30, 2003 | 12:04 PM
642642's Avatar
Those are the only two I put in.
Old Dec 30, 2003 | 05:49 PM
taqwache's Avatar
dam that suxs, what brand of springs are they?
Old Dec 30, 2003 | 06:26 PM
642642's Avatar
The EX-616 springs setup at 135lbs at 1.800” installed height, open up to 360lbs at 1.200”, and don’t coil bind until 1.110”.
Old Dec 31, 2003 | 01:12 AM
sbrown99TA's Avatar
Those are the wrong retainers, they are chromoly and a totally different design. Call CMotorsports up, they'll get you the right ones. They're good people over there.
Old Dec 31, 2003 | 01:14 AM
sbrown99TA's Avatar
p.s. I spoke with them today, they're answering machine message was done wrong, they were closed until December 30th, not January.
Old Dec 31, 2003 | 07:03 AM
642642's Avatar
Ya the people at CMotorsports are great. I got a PM saying to call them today to get things fixed. All a matter of time before im back on the road
Old Jan 2, 2004 | 10:31 AM
642642's Avatar
Still havent been able to get ahold of them...........
