Most agressive cam you can street??
My goal is a 10.7 pass. So since this is a daily driver i have decided heads/cam and "NAWZ" is the way togo. I will be using a 100 shot, but on my m6 what is the most agressive cam i can use in the street??? Something were i can still start on a hill, i live in the mountains, also with the clutch i have i can slip quite a bit but don't want to get stuck.
Thanks, SSL
Thanks, SSL
Re: Most agressive cam you can street??
Rear end gear is your solution to 230* and or bigger.Gearing will offset lack of accelleration at low rpm with good sized cam.I use max rpm lower end is good for as determining factor for cam size. Stock lS1 should be good for 7000 shifts so i would not go bigger than 230*, if it peaks at 6400 rpm you add 600 rpm for ultimate shift point and that puts you at 7000rpm.
