AFR LS1 205cc
We need more info.
How you ever had those heads flowed on an independent bench???? Those are some pretty amazing flow numbers.
Any info on what intake valves are in the AFR's?
Any more info in the article that can be posted?
The 205cc AFR's were compaired to the 201cc LS1, 211cc LS6, and 242cc CNC GMPP LS6's
You will not see those numbers since your motor will be a stock bore.
I will be amazed if you hit 500 without a fast intake and ewp.
.200 140 112
.300 200 170
.400 251 203
.500 281 221
.550 292 226
.600 301 230
from the AFR website, 205 mongoose street head with CNC.
Does not give much info on how these were obtained
http://forums.corvetteforum.com/zerothread?id=656708
He states flow figures are with a 390 bore about the half way down the first page.
-----INT EXH
.200 142 109
.300 215 146
.400 260 178
.500 286 212
.550 299 221
.600 304 227
These are a 3.905 bore size with 2.020/1.577 valves.
I don't know what the runners are but the 205 will definetly keep the velocity up. I am contemplating a set of AFR 76cc heads for my Turbo Setup. It will drop the CR down to 9.3 for me and the heads already come with large springs..they are ready to go..I am just waiting for Bill/AFR to make me the deal..for testing them out with a forced induction application.
I wish they will hurry up and release them so we can stop debating and find the facts!!!!!
OK they are 205cc but it is not ralistic giving flow #s based in 4.125 bore when most poeple have 3.905 bore.I understand what you mean but AFR have to base their test in the reality of the factory motor like they do when selling generation I and II chevy heads.Their base line was compared in factory bore size motors!!Just my .02 cents...
Happy new year everyone!!!
Smaller valved heads can flow 10cfm less so that should also be kept in mind.
I look forward to some independent testing.
Latest word from my foundry is still "good", and based on that we are still expecting the "launch" to be sometime the later part of this year as I have previously described....keeping my fingers crossed!
Ed....buy more shelving!!!
Regards,
Tony Mamo
1. Thinks STOCK 205CC CNC AFR heads could mean as much as 40-45HP over a STOCK LS6 with STOCK LS6 heads WITH JUST THE AFR HEAD CHANGE!!!!
2. AFR heads flow much better than LS6 heads with smaller port volumes than Ls6 heads resulting in much better power under the curve because of better air velocity thru the smaller ports.
3. Won't start shipping 205CC heads until Feb. 2004
****Tony says
Also, all my exhaust figures are recorded utilizing a 1.875 "flowtube" which is about 8-9" in total length. It bolts to the exhaust port much like a header and immediatly hooks down and back, closely resembling any primary tube you might find from the various manufacturers....after the turn, the pipe has about a 3-4" section of straight pipe.
f you have ever seen an Amduri flow tube, it is basically very similar. All my exhaust ports are optimized and designed that way from their inception so as to try and simulate real world operating conditions when ultimately the heads are sitting between your framerails with a nice long-tube header attached to them.
1.875 flowtube on exhaust for the AFR's? I would have expected more exhaust flow. Most of our cars will have 1.75 primary tubed headers & smaller bores so we would expect even less exhaust flow.
Tony's data is interesting but it's not really helpful as we don't have a common reference for most of it - yet.
Time will tell and I look forward to more data.
