need answers
Old Mar 8, 2010 | 10:15 PM
2000CG'STA's Avatar
Default need answers
is it possible to put a cam in a ls1 without taking out the lifters n if there is a way plz let me know need help fast.
Old Mar 8, 2010 | 10:17 PM
Nemesis350's Avatar
I'm sure if you do a search on the forum, you'll find your answer. There's a magnetic tool designed for this.
Old Mar 8, 2010 | 10:25 PM
V8MUSLE's Avatar
theres also a tool that slides in under them to hold them up. ls1howto.com has a good write up on it.
Old Mar 8, 2010 | 10:29 PM
Nemesis350's Avatar
(click the link below)
After i did a search, i realized there was way too much info for you to read just to answer your question... I do recommend you search the forums anyways, just to learn and familiarize yourself with everything, especially the stickys.
I will however redirect you ls1 how to, because there is a great write up on doing a cam install without removing lifters. Is it recommended? Most would say no, depending on the cam grind. But it's up to you to decide. I hope no one opposes to me posting this link.
http://www.ls1howto.com/index.php?article=23
Old Mar 8, 2010 | 10:34 PM
V8MUSLE's Avatar
when i did mine i just spun the cam a couple times and pulled it out. the lifters have a little "pocket" the get stuck in. from cam going out to new cam in was probably less than 5 minutes. if a lifter falls however...
