Quench Volume With 5.3 Heads
Old Mar 9, 2010 | 10:33 AM
99SS#20's Avatar
Default Quench Volume With 5.3 Heads
I have a set of ported, stock 5.3 heads with a set of 2.00 intake valves. With the small combustion chamber and the pistons 0.007 past the deck, what would be a good gasket thickness to keep my quench volume where it needs to be?
Old Mar 9, 2010 | 10:47 AM
69LT1Bird's Avatar
.035 is considered optimal quench for a street car so that means your minimum head gasket thickness would be .042.
Old Mar 9, 2010 | 11:46 AM
99SS#20's Avatar
Felpro has a .041 gasket, will this make my quench volume too small? I was thinking of using these for the compression bump, but I am concerned with quench and PTV.
Thanks,
Old Mar 9, 2010 | 12:21 PM
69LT1Bird's Avatar
Cometic makes any thickness you need. Call SDparts.com, they can get them for you.
The PTV needs to be checked.
Old Mar 9, 2010 | 01:05 PM
99SS#20's Avatar
I've read mixed reviews on cometics. Seems that they can be finicky to get to seal correctly. I was going to measure the PTV regardless, I was hoping to plan a setup that would most likely not need fly cutting.
Thanks,
Old Mar 9, 2010 | 01:23 PM
69LT1Bird's Avatar
Don't believe everything you read on here. The surfaces, block and head, are usually the culprit. The need to be very smooth.
