Convince me 346 or stroker?
but you can definately use your current headers, heads but may need to upgrade your injectors to #30's with a 383.
If you plan on building a power adder engine, I'd go with a forged 346ci setup. You can always boost it up or jet it up to make up for any lack of engine size.
The best all-around street/track engine I've ever owned was my all-bore 382ci. It made plenty of "usable" power, especially when launching on radial tires. I could floor it at the top of 2nd gear and start to grab. With the 434ci setup, I couldn't floor the car on the street until the top of 3rd gear, and its DAMN hard to keep that patience when you are racing someone. On the freeway, the 434ci was an ***-kicker, but I never lost with the 382ci either.
Just depends on what your purposes are really. I plan to put a stroker in my convertible because its heavy and needs alot more torque, and I don't plan on ever class racing it. The '88 Formula I just bought will be my next trailer queen drag car, and it will be a forged 348ci LS6, with alot of nitrous, spool, 9" rear, etc...
Tony
U can run 11.1CR or more and go bigger on the cam w/o sacrificing drivability,plus you'll have ALOT more TQ down low.
If I had the $$ I'd build a 383,The only way I'd go 427 is a Darton setup but there to much money...
Good luck...
Not true, I'm running faster than most of the big boys! Look at Harlan's car, he is soon to be the fastest car on the board! Power added of course...
Also, look at the Cartek 346ci bone stock bottom end cars with heads/cam running mid 10's at 130+ mph, naturally aspirated!
I say 346ci all the way!
Have Cartek build a 383 S2X REVIII setup and see what someone like Brent would run.There is NO way it wouldnt be quicker/faster.
But your car does flatout fly for a teeny tiny 346
No doubt 346's are very good,but line it up with a properly setup stroker and do a roll on at 40mph in 4th and the stroker will kill the 346 in torque..That makes a stroker a powerful street car.On the track it seems like most of the racers are ringing out 346's and going good,but I'm sure next year you'll be seeing more stoker motors running impressive #'s since the Eagle crank has made stroking affordable..(no pun intended
Most of the cranks available cost that by themselves....
How much are the eagle cranks??? They have been out for only ~ a month now.....
