ls1 rebuild
Give us a background on the car and what you plan to do with it. I can just start naming all kinds of stuff off to you, but it won't do you any good.
I have bought:
220/220 .581/.581 cam
comp cam lifters
comp cam rods (stock length)
PAC springs .600
SLP double chain
SLP oil pump
fuel raills
31 injectors
full off-road exhaust
delete panel for a/c
motor & tranny ploy mounts
ARP bolts everywhere
full gasket kit
TOTAL - about $1700 plus shipping
Let me know if you need any prices and places where I bougth the items
I am staying stock heads untill I can afford a full rebuild of the bottom end. I got to many miles.
1.) Get $500 from the ATM, and burn it.
2.) Drain the oil from your current engine, then run it until it blows.
This way, you get the same result but without all the time and effort.
If you are going to rebuild the bottom and on a budget keep the stock crank. Its good for along time. Since its all apart I would do a set of forged pistons, rings and if you have the extra money a set of forged rods. The rods arent bad but if you can afford them do it while its apart.
By doing pistons you can raise the compression some and gain a little power but dont expect alot. Rebuilding is more about making it stronger than about gaining power.
Your best bet for saving is to find a known good shortblock from someone who has crashed theirs, or went bigger. That will be your cheapest route I assure you. If you have never built an engine, and think that its just throwing parts in,That is a very expensive mistake.
