Wiseco dished piston to wall clearance
If what I'm thinking of what the machine shop guy said, then if they will work in a stock bored block then wouldn't the piston be measured at like 3.995-3.997? And that would still be a 402 right? (6.0 iron block). So lets say if the piston measures at 3.997 with a 4.005" hone that would be .008" clearance, or .010" clearance if the piston measures at 3.995. If that's the case, then taking a piston with that much clearance, would it be problematic for the 4.005" finished hone? I'm not sure of the clearance specs that these pistons need. I read somewhere that a Diamond 2618 piston spec sheet says .007" clearance. I will call the shop in the morning and have them give me the exact measurement of the piston.
Usually ~.004" is the norm for a 2618 alloy piston in a streetcar type engine. If you have too much piston-wall clearance, you can send the pistons out to get coated. The coating will take up that extra clearance, but by then, you might as well have bought new pistons.
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
However, if the pistons are too small, then the pistons are too small.
only problem with that is breaking more crap, and that it'll be NA until next year.ring grooves were measured 1/16, 1/16, & 3mm with spacer rail. 1/16 is equivalent to 1.58mm. any ring recommendations out there?
current topic is, opinions on .006" piston-wall clearance with the older Wiseco pistons. Will piston slap be annoying? and would you all recommend Hellfire or Total Seal AP rings? Will be ran NA as a daily driver for about 5k miles before the switch to boost (11-14psi). I'm just kinda worried about getting them seated.
Good Machine shops individually hone each bore to each piston and refuse to hone the engine without the pistons sitting right there being measured.
My .02.
My .02.
