What RA on deck surface of block for stock head gaskets?
I'm headed to the machine shop with my block this afternoon, but I wasn't sure what RA to have the deck resurfaced, if that winds up being necessary at all. If it turns out that I do need the deck resurfaced, what RA should the machine shop smooth it to for the stock MLS gaskets? I'll be running LS3 heads, so I'll be using the corresponding stock LS3 head gaskets.
I haven't seen a figure for stock GM MLS gaskets.Cometic gaskets require a finish of 50 RA or better but GM gaskets are much more forgiving.I would think whatever the machine shop normally does should be fine for GM gaskets.Sorry I can't be more help.
