Rocker ?
Old Mar 20, 2010 | 11:05 PM
ALPz28's Avatar
Default Rocker ?
i have a brand new valvetrain with about 2000 miles which consists of trick flow cam .598 238/242, trick flow rods, comp springs, stock heads and rockers. i was considering the 1.8 rockers to get the extra lift (.630ish) out of the cam and more power hopefully but wanted to know if it was worth it in the end or if i should just go with 1.7. i plan on getting trick flow heads so would like that to be taken into consideration also.
thanks
Old Mar 21, 2010 | 02:45 PM
RARON455's Avatar
Pretty sure the trick flow heads require and come with harland sharp rockers.
Old Mar 21, 2010 | 05:27 PM
SOMbitch's Avatar
Yeah you need to stay with 1.7's. I prefer Yella Terra over HS but either is fine.... Jesel if you are feeling frisky....
