Lunati Gold Dual Valve Spring Kit w/ max lift of .660
Old 03-21-2010, 10:06 AM
trans_am7935's Avatar
Default Lunati Gold Dual Valve Spring Kit w/ max lift of .660
What do you guys think of these springs. i am getting a pair of 243 heads and going to put these springs on them. maximum lift capability at 0.660-inch, and only 225 bucks! i want to know if they are any good. i was going to use them with an LSR cam with specs at Int. 231 Ext. 239 Lift Int. .617 Exh. .624 LSA 113° does anybody have experience with these springs, and if so some advice if i should get these ror comp cams 918 springs?
thanks
-David
Attached Thumbnails Lunati Gold Dual Valve Spring Kit w/ max lift of .660-4d-lunativalvetrain.jpg
Old 03-21-2010, 10:11 AM
SOMbitch's Avatar
I have NEVER seen anything Lunati that was not top notch. I used to run Lunati in my Gen I stuff whenever I could afford it.
In all honesty I have never known anybody to run their springs in Gen III stuff but that would not me scare away in the least
Old 03-21-2010, 01:31 PM
adkunlimited's Avatar
im running the lunati rollar rockers and will be getting the springs soon also. if they sold valves i would buy them. top quality
Quick Reply: Lunati Gold Dual Valve Spring Kit w/ max lift of .660
