Zero oil pressure pump failure?
Old Mar 22, 2010 | 10:36 AM
12leavu's Avatar
Default Zero oil pressure pump failure?
I lost oil pressure this weekend , started getting valve train noise, started car Again and it had pressure, drove car one mile parked it, no noise and it had oil pressure. Restarted car again zero oil pressure and valvetrain noise again. This Is 402 ls2 been in car for 8000 miles. I changed the filter wondering if it was clogged and hooked an external oil pressure gauge to it, crank for just a second still has no oil pressure, could the pump have failed, the car was idleing when it lost pressure. I didn't hear anything break or pop
Old Mar 22, 2010 | 10:52 AM
Jon@Texas-Speed's Avatar
Start by changing the oil and see if there is any metal in the oil. It would also be a good idea to cut the filter open to see what it looks like as well. It wouldn't think it would be a pump but anything is possible. Does it sound like the noise is coming from valve covers or elsewhere in the motor?
Jon
Old Mar 22, 2010 | 11:03 AM
12leavu's Avatar
Valve covers. I started it up with new filter I filled filter before insatlling it, I let it run about 4 seconds oil pressure never moved, the confusing part is that it came and went. I'm wondering if my pick up tube bolt rattled lose
Old Mar 23, 2010 | 10:28 PM
12leavu's Avatar
The pressure bypass valve was stuck open inside the pump, maybe this will help someone in the future.
Old Mar 23, 2010 | 11:44 PM
Good to hear you got it fixed! Was there some trash in it?
Jon
Old Mar 24, 2010 | 10:51 PM
12leavu's Avatar
Thanks, I assume there was, but I just went ahead and replaced pump. This is a Texas speed 402 btw, been running strong 2 years!
Old Mar 25, 2010 | 09:57 PM
Mrs.Nos's Avatar
How did you tell that it was stuck?
