cam swap without removing oil pump
all you have to do is make a line on both the timing chain and timing gear and place the car in to 6th gear (you prabaly have already to remove the balancer) to make sure the crank does not turn and when you install the cam you just line up the mark you have made on the cam gear and the chain
has anybody done it that way or am i just being lazy ?
You only have to remove the oil pump if your doing a crank sprocket change or a timing chain upgrade.
it is strange that he changed just the timing chain , i would of asked the previous owner as to why he changed it but unfortunately he has passed away
Or do like I do, install a degree wheel on the nose of the crank, find TDC #1 with the piston stop, set the degree wheel, and degree the cam in acording to your cam card that should have come with your cam. I degree every cam in even if I can see the dots. You would be suprised how many cams are not exactly were they are supposed to be by just using the dots.
My advise is either degree it in, or if you do not have a degreeing kit and if you are not sure you can do this, then drop the pan down some, pull the oil pump, REPLACE the o-ring, and use the aftermarket bracket for the pick up tube. I can never remember the name of the bracket! Maybe someone on here will chim in with the name. It goes on around the pick up tube and uses two bolts to secure the tube to the pump from both sides. It will help prevent screwing up the o-ring and having leaks there.
Good luck and let us know how it goes.
JK, but I don't think I would ever change a timing chain on an LS1 at 75K unless I had been beating the heck out of the car..... you place the #1 cylinder at top dead center and the mark on the cam gear should be pointing straight down on to the crank ?
