cam install quesion
Old Jan 4, 2004 | 12:15 PM
RaNsOm's Avatar
Default cam install quesion
Im going to be installing my B1 here shortly, and a buddy of mine is going to be doing the major parts of the install helping me along the way. He said I'm giong to need an air compressor to put air into the cylinders to keep the valves up when changing the springs? what exactly do I need to do that? also what Valvespring tool would you recommend?
Old Jan 4, 2004 | 12:30 PM
wrencher's Avatar
wrencher
A compression gauge fitting with the 1/4" air nipple to fit a 1/4" standard hose coupler.
There are alot of valve spring tools it's a matter of preference.
I use the standard compressor w/the faucet handle, it is small to get under cowl.
Some like the tool from more performance>>> sponsor list>>>How about some pen magnets to ensure no lifters fall into the oil pan??
Old Jan 4, 2004 | 01:01 PM
Ferocity02's Avatar
You need to rent or buy an air compressor and some fittings so you can attach the air hose to the spark plug hole. However, you can do the top dead center method as an effective alternative. Some say that it goes faster than the air compressor method.
As for the spring compressor tool, I would not suggest the MORE tool, simply because it costs to much and I think I heard it can't get the back springs. I would also not reccomend the ones you rent from Autozone because they have a tendancy to break the bolts off in the heads, turning your cam swap into a nightmare. I used Larry Sample's tool and it worked VERY well, got to the back ones like they were nothing. There is a thread about his tool in the "Tools of the Trade" section, I'm not sure if he has any left but you could make your own based on his design...
jmX's Avatar
jmX
You definitly do not need an air compressor, and in fact I recommend the "Top Dead Center method" as depicted and described here: http://www.ls1howto.com/index.php?article=23
Old Jan 4, 2004 | 01:05 PM
98SS Blackattack's Avatar
A few things here. I would use the TDC method instead of air compressor.Just turn the crank. The valves will sit on the pistons. 2nd 1/4 inch plastic tubing will work to keep the lifters up. They slide in around the cam,you will see what i mean.Larry sell a great tool under tools of the trade section. Its the best type. Great cam by the way
Old Jan 4, 2004 | 07:24 PM
Y2K2LS1's Avatar
Any pics of this?
I used pen magnets once and one got stuck in the lifter retainer thingys and broke. The last 4" or so with the magnet were in the galley. Thank god the really thin needle nose pliers barely got in there. Never again.
I would really like to see a pic of this. Are there holes in the block for the tubing to slide in or something? And they block the lifters from falling?
Thanks
Old Jan 4, 2004 | 08:44 PM
x phantom x's Avatar
STF veteran / 10 second club
I use both the TDC method, and compress the cylinder. I feel that when the cyl gets compressed, the valve stem sits up alittle higher and it is alittle easier to get the keepers on the stem. Also, I do the TDC method as a backup just incase the air cuts off for some reason the valve doesn't go falling into the cylinder (I'm sure that would suck).
Old Jan 4, 2004 | 09:10 PM
Jorday's Avatar
Originally Posted by Y2K2LS1
Any pics of this?
Thanks
I saw this happen on a car that was having a cam change. Luckily, he got the pen magnet free without breaking it by pulling it out hard.
Old Jan 5, 2004 | 12:21 AM
DEPHUDSON's Avatar
Default Cam Install
Whats A Good Way To Keep Lifters From Falling During Cam Swap Besides Pen Magnets?
Old Jan 5, 2004 | 12:29 AM
eallanboggs's Avatar
AutoZone loans out a OEM brand compressor tool that compresses the spring directly without using the rocker bolt threads for leverage, but with the money you save by doing this job yourself you should be able to afford your own spring tool.
Old Jan 5, 2004 | 03:23 AM
jmX's Avatar
jmX
Here's a new tip that I have yet to add to my website.
I've noticed on newer cars that pen magnets seem to get stuck down in the lifter retainers. It could be the style of magnets those people were using too, but either way, clean the magnets and about 3" of the magnet stem right at the base of the magnet and TAPE TIGHTLY around the base. The problem with them getting stuck is that the lip of the magnet tip gets caught inside the lifter retainer, so if you put a tightly wrapped piece of duct tape, packing tape, something that wont come loose around the base, they won't get caught and will come right back out really easily.
Old Jan 5, 2004 | 08:32 AM
Any pics of this?
Thanks
I dont have picks. But its like using the JPR lifter tool.go to www.ls1howto.com and look at the cam install write up. There is a pick of the jpr tool in action.
Old Jan 5, 2004 | 08:47 AM
Larry's Avatar
I should have more in about two weeks.
Old Jan 5, 2004 | 10:44 AM
Zanthius's Avatar
As for me, I followed jmX's advice on ls1howto and ordered the JPR lifter tool. I only checked one place but those stupid magnetic pens cost $4 each so I didn't fell like spending $65 on 16 of them. Might as well get the JPR for $80. Since I already had a compressor, I also went to the parts store and picked up the fitting.
Old Jan 5, 2004 | 03:07 PM
RaNsOm's Avatar
I'm thinking about just using the TDC method for the valves...is it any less safe than using an air compressor?
Old Jan 5, 2004 | 04:26 PM
jmX's Avatar
jmX
I would recommend that if the timing cover is off, everybody use the TDC method. The only downside to the method is that the valve does drop maybe a quarter inch, and that can sometimes mean you have to compress the new springs even further before the valve locks will fit in...just a little annoying, but nothing major. With air, the valves stay all the way up so you wont need to compress the springs as much.
Old Jan 5, 2004 | 04:43 PM
Cal's Avatar
Cal
Another vote for the TDC method. And the valve droping 1/4 inch wasn't a probelm for me; I just grabbed the valve stems with my fingers and pulled them back up before putting the valve locks in. They will stay up because of the friction in the valve seal.
