How do I diagnose a bad main cap bearing?
I have a 99 LS1 with 178XXX(3rd owner. 2nd owner says the first owner rebuilt it) miles with an auto. I first thought it was a bad pulley because it sounds exactly like it but I checked all the pulleys and they are fine. The sound is coming from the rear of the motor. I have a bad rear main seal I have oil between the motor and tranny and also the oil pan idk if that's it?? I changed the oil and no sign of any metal shavings. The motor doesn't hesitate at idle or any RPM. The squeeling does go with the RPM. If it is a bad bearing do I need to get a new crank and main caps? Thanks in advanced.
did you cut up the oil filter? if there is a bad bearing the crank will have to be checked by a machine shop. but you shouldnt need new caps (unless its really bad) just new bearings. the only way to really know is to pull the oil pan and take a look for yourself. rear seals are really easy to screw up so the first owner might have installed it wrong and i took this long to become noticable. hows your oil pressure?
