Oil pump removal??? please help
Old Apr 2, 2010 | 12:15 AM
MJR7AD's Avatar
Question Oil pump removal??? please help
Hey guys, i need to know if you can remove your oil pump and put a new one in with the oil pan still attached, and not removing the motor. I know you would have to remove all the front harmonics, but is it possible to do all this without removing the oil pan?? Is there any websites that show how this is done?
Thanks again
Old Apr 2, 2010 | 12:47 AM
no1izspeshl's Avatar
ls1howto.com
Old Apr 2, 2010 | 01:35 AM
Ferocity02's Avatar
You need to unbolt the oil pan and lower it some to get to the oil pick up tube bolt. You don't need to remove it totally.
Old Apr 2, 2010 | 11:50 AM
MJR7AD's Avatar
Hey thank you so much guys, that ls1 how to hit it right on the head..
Thanks
Again
Old Apr 2, 2010 | 03:59 PM
Squirts11's Avatar
For a tip, tie some light string around the bolt. This will not only help you retrieve the bolt if/when you drop it in the pan, but you can use the string to pull upward pressure on the bolt while installing it, to keep it from dropping until it threads.
Old Apr 2, 2010 | 11:24 PM
BuBbABFP's Avatar
When I did my H/C swap, my buddy took out the bolt without tying anything to the bolt lol he was shacking so bad when he was doing it..haha
Old Sep 27, 2011 | 09:49 PM
UnZFeat'd's Avatar
it seems like the pan cant go down far enough to get to the god damn bolt for the pickup tube. i cant even fit a wrench in there
Old Jul 27, 2012 | 08:43 PM
kunkelz28's Avatar
unZFeat'd is having the same problem as me... pan can only drop about 1/4 of an inch... i really dont' want to rip the engine out to get the oil pump off... any help
Old Jul 27, 2012 | 08:51 PM
01_SuperSlow's Avatar
You need to loosen all bolts including the 2 long ones by the bellhousing and a ratcheting wrench for the pick up tube bolt.
Old Jul 27, 2012 | 09:04 PM
therabidweasel's Avatar
You can get it and I highly recommend string, I used a slipknot in kevlar fishing line.
Old Jul 27, 2012 | 09:13 PM
kunkelz28's Avatar
alright thanks guys.... i will give it a try....
Old Jul 27, 2012 | 09:33 PM
gMAG's Avatar
I like to put a rag just inside the pan, flattened, just in case the bolt DOES drop. It'll keep the bolt from bouncing down into the pan.
