Cheapest 4" crank?
Old Apr 2, 2010 | 02:53 PM
Isolde's Avatar
Default Cheapest 4" crank?
What's the best price out there? Preferably a cast steel version, like Scat or Eagle. This build doesn't need 4340 forged. BTW, it's 24x.
Old Apr 2, 2010 | 02:58 PM
elias_799's Avatar
i do not think anybody makes cast steel cranks. scat and eagle make forged steel cranks.
forging method creates much stronger pats
the factory crank is cast iron
Old Apr 2, 2010 | 03:06 PM
rickou812's Avatar
There is one that is non-forged for around $550.
I saw it in one of my recent parts books. I am at work now, I will post up more info when I get home.
Old Apr 2, 2010 | 04:18 PM
Isolde's Avatar
I would very much appreciate it. Thanks in advance.
Old Apr 2, 2010 | 04:21 PM
Isolde's Avatar
Since Eagle can do a cast steel stroker SBC crank for under $200, there's no reason they shouldn't do the same for the LS for under $500. I've had a supercharged 383 hit 640 HP at 6000 rpm with a $250 (new) cast steel Scat stroker crank, a 350 SBC stroked to 383. Cast steel will more than suffice for a <500 hp LS.
Old Apr 2, 2010 | 04:26 PM
sgm98ws6's Avatar
cheapest one i have seen is the callies lsc 530 something ... ill send you the link. Friend is using one in his 408.
Old Apr 2, 2010 | 07:48 PM
Isolde's Avatar
Thank you again, very much!
for everyone else, here it is:
http://www.notsasponsor.com
Last edited by Patrick G; Apr 20, 2010 at 03:33 PM. Reason: non-sponsor link removed
Old Apr 2, 2010 | 07:53 PM
rickou812's Avatar
http://www.notasponsor.com
That is the one I was referring to, but from a different vendor.
Last edited by Patrick G; Apr 20, 2010 at 03:34 PM. Reason: non-sponsor link removed
Old Apr 2, 2010 | 09:47 PM
elias_799's Avatar
the stock cast iron crank will hold more then 500hp no problem so the cast steel unit should be even stronger if done properly
Old Apr 2, 2010 | 10:30 PM
Moneyshott's Avatar
I got one for you. Send me a pm.
Old Apr 2, 2010 | 10:34 PM
Jon@HKE's Avatar
Closed ex-Sponsor Account
The Callies C-Series stuff is probably your best bet.
http://store.hkracingengines.com/pro...products_id=51
Old Apr 2, 2010 | 10:37 PM
garygnu's Avatar
try SDPC.
Old Apr 2, 2010 | 11:53 PM
LilJayV10's Avatar
What is the stock crank made out of?
It will push 1000hp+ plus
There is no reason you can't make it out of the same material and it be as strong.
Old Apr 2, 2010 | 11:59 PM
elias_799's Avatar
read my first post
i personally would not push a cast iron crank to 1000hp, atleast not without treating it
Old Apr 3, 2010 | 07:11 AM
Isolde's Avatar
thanks, but not ready to buy until after April 15, ya kno????? Just want to have something lined up for whenever my big refund does finally arrive.
Thanks everyone.
Old Apr 3, 2010 | 03:14 PM
racer7088's Avatar
We sell those at a decent price and can balance it as well for your rotating assembly.
Old Apr 3, 2010 | 03:16 PM
racer7088's Avatar
NO one makes a cast crank LSx 4.000 yet but I am sure someone will at some point as it's been over ten years now with only steel cranks!
Old Apr 20, 2010 | 01:17 PM
JimMueller's Avatar
I called Callies and they said as long as you're under 650HP peak at the motor it's OK to use. Said it was designed more for trucks that do hauling. Would this be OK to use as a crank in 416 LS3 with stock LS3 heads and aftermarket cam?
Old Apr 20, 2010 | 01:55 PM
racer7088's Avatar
Yes it should be fine Jim. For extreme NA or high rpm or power adder use I would use the regular 4340 crank but these should work fine on an NA normal hydraulic roller engine.
Old Jan 4, 2012 | 01:51 AM
lsxnation's Avatar
bringing back an old thread.. i've heard about an aftermarket crank for around 500 , any-b know the company, more info.. link maybe?
